2012 Pete runs for 15 minutes and runs out of fuel
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Pavelito, Jan 29, 2020.
  1. Pavelito
    Pavelito Bobtail Member
    I park my 2012 Pete and go home next day I turn it on no problems, but after 15 minutes runs out of fuel and shuts off,I have to take the gas line out and turn the ignition on so it will fill up with fuel again.after is running it won’t do it again . Just after is been park. Please help
  3. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,080
    Sep 24, 2019
    Raleigh, NC
    How old is the fuel filter?
    Chubby Fly Thanks this.
  4. Pavelito
  5. lwlevens
    lwlevens Medium Load Member
    623
    427
    Feb 9, 2018
    Did you just change fuel filters? Sounds like it's losing prime.
  6. FdEF
    FdEF Light Load Member
    70
    57
    Dec 5, 2017
    Ogden, Ut
    You've got a cracked fish bowl or a line that's cracked sucking air
  7. Chubby Fly
    Chubby Fly Medium Load Member
    569
    797
    Nov 25, 2019
    check fuel tank vent too
  8. truckerdave1970
    truckerdave1970 On Probation
    2,987
    3,289
    Dec 15, 2008
    Rochester, NY
    not that i have ever done this but...:oops:;)
    a sandwich baggie dropped in a fuel tank will do that too. the baggy gets sucked into the line, stops the fuel, truck dies, the baggy floats to the top of the fuel barely visible. Start the truck and it will do it everytime
  9. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    had a similar issue with my 2012 386
    What we did
    is take the line off from the fuel filter ( clear fish bowl). Put it in a bucket of fuel and fire it up if it runs then from there
    Start taking the fuel lines from the truck the thin ones. Unscrew it fold it zip tie it and run the truck if it dies then you do the other one if the truck runs then you know your issue is that line or the tank.
    For us it was the fuel tank. It broke inside
    To get the truck home ran it on one fuel tank then swapped the “ bad thank” with a different one and the issue went away.
