A good cleaning of the EGR system may be a start. Rawze has videos of that. If it is not working fully the system senses the reduced flow and may reduce power to compensate.
It is not complicated to do, just very messy.
Also check the intake system for boost leaks. Charge air cooler leaking.
2013 ISX 15 CM2250 Low acceleration, power, and mpg.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by TheOgre, Oct 11, 2019.
Page 2 of 3
I definitely think taking it to a dealer is an option for those kinds of things. We aren't looking to tweak with anything specific in the calibration, but to simply update the calibration with what Cummins provides for our CPL. Do you think it could be as simple as that?
We have Cummins Insite on our machine, but we don't actually own the Data Connector yet as it's quite a purchase to make if we don't absolutely need it yet. (Looking like we might though)
Will definitely look into a forced regen! Thanks!Last edited: Oct 12, 2019
Reason for edit: Changed 45mph to 35 -
We have checked the intake for boost leaks, 28PSI is maintained at the intake mainfold through heavy-load situations, we have leak tested from the turbo to the manifold, and there were no noticeable leaks anywhere in the system. Seems the CAC, turbo, intake manifold, and hoses are all airtight. This was one of our first thoughts as well. -
TheOgre and Tx Countryboy Thank this.
TheOgre and spsauerland Thank this.
It doesn't take much of buildup in the Venturi tube to throw off Delta P readings and start the cycle of way to much EGR flow. More EGR flow equals less power and more fouling of air management and after treatment. Rawze has good YouTube videos and take no short cuts. Clean it all.
TheOgre Thanks this. -
Intothesunset Thanks this.
Nobody is going up those big hills when loaded very fast. There's probably a small % of dudes running some 600HP super engine, but that's not gaining them a whole lot.
That new hill on I-11 between Boulder and Henderson will test your motor. Went up that a dozen times this summer at about 78K. Outside temp was 110 to 112. Couple times I dropped it into 6th as my temp gauge didn't want to go below 220.
You wanna roast your motor and hang out wrenching on it with the boys, more power to you. I got freight to move.Intothesunset and Tx Countryboy Thank this. -
I wish I could help. But I hope the fuel pump has been check or replaced, cm2250 is notorious for carbon packing that leads to dropped liners as well. You may end up rebuilding that engine to suite your needs. And a Non emission isx can do well with fuel mpg. There is a nice tune for 425hp, 2300tq but that is a lot of torque. Also the fuel actuators can go bad and test good. Do not buy Reman fuel actuators.
Page 2 of 3
