2013 Volvo D13 fuel injector issues
Discussion in 'Volvo Forum' started by Royalknight1, Nov 6, 2018.
  1. Royalknight1
    Royalknight1 Bobtail Member
    6
    Nov 6, 2018
    Hey guys right of the bat, If you want to skip to the question I will divide it between how I ended up with this truck and my issue that I hope some of you can answer.
    So i took the route of an owner op. And I purchased a 2013 volvo 780 D13. I kinda took a risk it because it was priced good, had very low miles/hours for its year, at 420k miles for only $35,000. The truck had absolutely brand new Michelin tires and new alco wheels all around. New shock absorbers and t arms. Ran perfectly fine, no engine codes, good engine idle, pulled good for a 425hp, so no syptoms. So after I made a purchase 2 months down the road I noticed the oil slightly rising, so I asked around and people recommended an oil analysis. When I sent it out it came back with 14% fuel in oil that I just recently changed. I sent out the old oil as well and it had 28% fuel in oil. I took it to a shop and here is what they said
    I have 1 bad fuel injector, #2 and it is putting fuel in the oil. Now with further inspection they noted I will need to replace my camshaft and rockers because the oil/fuel chewed it up. Ive done several engine rebuilds in car engi e and my personal opinion tells me my cam is not as bad as he is saying. My question is, how many of you guys ran on a cam that was chewed up but truck ran and pulled good. I would like to run on this cam until I save up some money, they quoted me $12k for parts and labor. I will still do the fuel injectors which is like a $4,600 repair but to clarify the question are there guys out there that ran on a chewed up cam and had either issues or success? 20181106_174501.jpg 20181106_174501.jpg 20181106_175144.jpg 20181106_174430.jpg 20181105_130605.jpg 20181106_174311.jpg 20181106_174244.jpg 20181106_174226.jpg 20181106_174657.jpg 20181105_130618.jpg
    NoBigHurry and Johny41 Thank this.
  3. I glide 47
    I glide 47 Road Train Member
    1,430
    1,505
    Jun 3, 2017
    What future damage will that cam cause
  4. Royalknight1
    6
    Nov 6, 2018
    I'm not sure, possibly misfire. I'm just trying to see if anyone ran there truck with a chewed up cam shaft and how long it lasted before they got issues.
  5. Benek
    Benek Light Load Member
    83
    38
    Feb 10, 2016
    Same thing happened to me, injector #2, caps leaking, cam damaged, rockers damaged. Ended up replacing all at once. All the injectors, caps,& cam. $14k with some change. Injectors needed to be done, so what the heck, do the cam as well, why open it twice? Labour is costly. Btw,truck was strong before as well as after
  6. Royalknight1
    6
    Nov 6, 2018
    Wow i thought 12k was allot. yea I would not hesitate it's the funds that are not letting me do it. If done seperate the labor for cam work is 2700 and 950 for injectors. If together then they said injectors will cost $500 to replace, cam price stays the same. so it's not that big of a difference. I was hoping I can run maybe 40k miles and then change the cam. That way I have funds and dont have to loan money.
    Tybo1981 Thanks this.
  7. nasriza
    nasriza Road Train Member
    2,133
    1,721
    Feb 1, 2013
    Chicago, IL
    well i have two question, first is that if it is only one injector leaking then there is no need to replace all of them specially if the truck is driving fine, your cam looks pretty worn and i dont think you have much time until it goes out all together but 12K seems quiet extensive to me. if the truck is running good then do an oil change and hit the gas but the problem is if that cam does go out its going to go out on a hard pull and then depends on where u are you are going to pay an arm and a leg just for the cam this is something you have to think about as well.
  8. Benek
    83
    38
    Feb 10, 2016
    $14k i quoted was in Canadian dollars
  9. Johny41
    Johny41 Road Train Member
    1,174
    973
    Feb 10, 2011
    Ontario, Canada
    I paid about same amount for camshaft and injectors 4 years ago, at Volvo Expresway in Ayr, Ontario on last truck, but i was at 1,320,000 miles .
  10. Royalknight1
    6
    Nov 6, 2018
    I really appreciate you guys tuning in, and helping me decide. I think you guys are right, its really not worth running this damaged cam and rockers. The route im going is actually to find a good condition cam and rocker set and run it until i can save up money for new parts. I just found a deal on all the rockers: Dealer price was $4900 for all rockers, i picked up a used set in good condition for $250. If i can find a cam for under 1k used this rebuild will cost me $6200 instead of $12,000. Thats new fuel injectors/cups, good used cam and rockers with labor :) For guys that run into the same issue as i did, look into used, its not the best option but when you have absolutely no funds, there are a ton of good D13 engines from rolled over volvos. AGAIN THANKS :)
  11. SanelHusidic
    SanelHusidic Bobtail Member
    9
    If anyone could help me please having hard start when truck sits for about 15 minutes takes about 5 to 10 seconds to start the truck when the truck starts runs okay no idle problem and fule milage is good as well was told 6 injectors are bad with a bad fuel housing as well could this be the problem really and just did the injectors about 140k miles ago
  • Draft saved Draft deleted
