2014 Cascadia with codes SPN and SPN 986.
Discussion in 'Freightliner Forum' started by biiqtruckin, Oct 28, 2021.
  1. biiqtruckin
    biiqtruckin Bobtail Member
    27
    Sep 20, 2017
    Hello, I just scanned my 2014 cascadia and it came up with these codes
    SPN 793 wheel speed sensor abs axle 3 left
    SPN 986 requested percent fan speed
    The abs one.. Just want to know which row it is in the back. Is it the 2nd row rear left wheel sensor?
    Also the fan speed.. is there something up with the fan clutch?
    Thanks
  3. SWM_TECH
    SWM_TECH Light Load Member
    139
    145
    Apr 15, 2018
    For SPN 986 you didn't give the FMI but looks like 13. Found this diagnostic steps. If it matches, maybe it can give you some direction.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,294
    Apr 9, 2009
    Humboldt, Sk
    Yes, count the front axle as number one. So rear drive axle.
  5. biiqtruckin
    27
    Sep 20, 2017
    Thanks fellas.. well the full code list is attached here. If anyone has any experience with these.. that'd be cool.
    I actually just went ahead and purchased the abs sensor for the rear. So whatever that code was, it's worth a low cost sensor anyway.
    I refilled the coolant reservoir so im assuming that the code was in correlation with the fan speed?
    The adaptive cruise control code always comes back after I reset it? This one has been here for months.
  6. SWM_TECH
    139
    145
    Apr 15, 2018
    Here are several diagnostic fault trees to match your updated information.
    QUALITYTRUCK Thanks this.
  7. Rideandrepair
    17,306
    56,153
    Aug 8, 2015
    Depending on what type sensor you have. A long wire or short wire. If short wire, might want to try changing the extension wire to ecu, before changing sensor. Much easier. If long, one piece wire, no choice, have to Change sensor. Try pushing it in up against the tone ring from behind first. I like the short wire w/extension wire better. Since it’s usually a broken wire between sensor and ecu causing the problem.
