Hello new to the forum
I got a 14 pete with isx hask 286k
Engine took a poop due to fuel pump failure had inframe done rebuilt fuel pump replaced 6 injectors with rebuilt ones been out the shop 3 weeks fuel rail pressure warning came on i took it back to shop and mechanic changed out 2 injectors 2 days later same warning came back on he changed out 4 injectors and now 3 days later light is back on is there anything else that can be causing this?
Im located in los Angeles area ca. Thx for any info
2014 peterbilt isx fuel rail pressure warning
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by BIG DAWG 1, Sep 20, 2019.
I am not an expert, my understanding is that if the fuel pump pistons shatter and take out the motor it can't be rebuilt because the metal fragments can't be fully removed from the fuel system. I would call Cummins customer service and ask them.
If its a 559 code it could be a leaking fuel rail pressure relief valve or a faulty pump head and or pump cam/followers.
Is the mechanic actually following the 559 troubleshooting steps? What is the actual code?spsauerland Thanks this. -
Take it to Cummins. I highly doubt it has anything to do with the injectors.
I have a 2014 with Cummins that was running very poorly all of a sudden and it was the fuel rail. I’ll have to see what they replaced but it definitely wasn’t injectors. -
Injectors can absolutely cause low fuel pressure. Being they have all been replaced, probably not the case anymore in this instance
