2014 prostar what might cause code spn 1569 fmi14
Discussion in 'International Forum' started by Cencalmechanic559, Mar 13, 2023.
  1. Cencalmechanic559
    Cencalmechanic559 Bobtail Member
    4
    I loose power and tractor only goes 5 mph
  3. JB7
    JB7 Light Load Member
    222
    291
    Dec 13, 2022
    Truck is in Derate due to aftertreatment problems. The 1569 is the important part, the FMI 14 not so much.
  4. Cencalmechanic559
    4
    Thanks appreciate the info what do you think might cause this? I have no other after treatment related codes
  5. JB7
    222
    291
    Dec 13, 2022
    Could be so many things. What is your DEF level? Someone will need a scan tool or computer to get the data, then see what is out of range. There is a pressure sensor before the DPF and 1 after, NOx in and out sensors, temp sensors..... One would think that it would have set some other codes. Upstream problems can cause issues in/with the aftertreatment such as air intake or exhaust leaks.
    You could pull out the DEF doser. They can get carboned up or dried/powdered DEF all around it.
  6. ChuckMartel
    ChuckMartel Light Load Member
    160
    94
    Jan 22, 2021
    Post all codes you have along with engine
  7. Cencalmechanic559
    4
    Spn 157 fm14
    Spn 1569 fmi 31
    Spn 520892 fmi 13
    Spn 524285 fmi14 those are all the active codes atm
  8. JB7
    222
    291
    Dec 13, 2022
    SPN 157 FMI all are for Rail Pressure
    All the other codes are likely caused by the high rail pressure. This causes a problem in the aftertreatment which in turn causes the derate.
    I don't see a 524285 but I am working off of a Cummins code list which should be the same for J1939.
  9. Cencalmechanic559
    4
    Thanks a lot for the info and your time and Is the fuel quantity sensor the same as the fuel
    pressure relief valve ?
  • Draft saved Draft deleted
