2015 Cascadia No Crank/Red DEF Light/Neutral To Start Engine
Discussion in 'Freightliner Forum' started by Ult2021, Sep 15, 2021.
  1. Ult2021
    Ult2021 Bobtail Member
    Hey, we have a 2015 Cascadia that has not been cranking and has Red DEF light and message saying Must be in Neutral to Start Engine. Any ideas as to what can be wrong?
  3. Ross_Tech
    Ross_Tech Light Load Member
    133
    134
    Aug 31, 2021
    PT CAN communication fault. Possibly CPC failure. It sounds like the ACM and TCM aren't communicating with the ICU or MCM.
    msh and QUALITYTRUCK Thank this.
  4. QUALITYTRUCK
    1,802
    1,764
    Jun 14, 2009
    romulus,mi
    X2 on CPC failure. Super secret galactic back order on module. Going for $2000 and up on Ebay.
    msh and Ross_Tech Thank this.
  5. Ult2021
    We got a used cpc, but still does not work.
  6. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Did you turn the truck off while it was in gear? When you turn the key on can you hear the trans. going thru the gears like it does before starting the eng>
  7. Ekluigy
    Ekluigy Bobtail Member
    5
    Oct 4, 2021
    I have the same in cascadia 2014 but a used a eaton transmision 13. I have 1 fault code about acm no connection and i work in troubleshooting and change the acm but still not start the engine.
    Any one help me?
  8. msh
    msh Light Load Member
    159
    110
    Jul 18, 2021
    Los Angeles, CA
    Many parts are on back order .... what is going on with our country ?
  9. msh
    159
    110
    Jul 18, 2021
    Los Angeles, CA
    cpc must be reprogrammed to that truck . putting from one truck to another will not work
  10. Ult2021
    We were able to resolve this, was a fuse.
