2015 Volvo d13 overheating and build pressure in coolant system please advise what is the problem
Discussion in 'Volvo Forum' started by usaexpress, Nov 7, 2019.
  1. usaexpress
    usaexpress Bobtail Member
    11
    do you know how to check those parts?
  3. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Ok
    If cups are the problem it will push coolant from the drivers side but do a search on here about leaking cups.
    The cooler can do a visual inspection and look for carbon balls at exit of the cooler. Can also pressure test the cooler.
    The compressor..... drain the wet tank and place a clean rag (white one works best) see if the moisture comes out red like the coolant. I am sure there is a better way but this is pretty easy to do.
    usaexpress Thanks this.
  4. usaexpress
    11
    Ok I will check thanks
  5. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    my next step would be to look between radiator and charge air cooler probably plugged up with debris and bugs if you can wash it out should work do not use a pressure washer.
  6. usaexpress
    11
    It’s clean getting pressure even at 170, 180f temperature
  7. nasriza
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    If there is pressure than possible air compressor or egr cooler.
  8. nasriza
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    Do u have coolant loss. And can’t find out where it’s going.
  9. usaexpress
    11
    It’s getting pressure bubbling and pushing out from overflow
    I think it’s injector cups
  10. nasriza
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    Check make sure it’s not air compressor before you replace cups not as big of problem as they were in older Volvo’s
  11. usaexpress
    11
    Ok Monday I will take it to shop
