2016 Automatic Cascadia DD15- loses power, all lights come on dash, speedometer etc stop working
Discussion in 'Freightliner Forum' started by Roiltransport105, Sep 22, 2023.
  1. Roiltransport105
    Roiltransport105 Bobtail Member
    2016 Automatic Cascadia DD15 engine.
    Truck was losing power. Multiple times to the mechanic. Here is what has been done so far:
    1-Replaced and programmed new CPC
    2- Replaced clutch
    3- Replaced engine air filter
    4- Replaced Samcab
    Problem persisted until Samcab was replaced. After that, truck worked perfectly for about a week. Just got word that same problem is happening. When this happens a beeping noise occurs, then check engine lights come up on dash, truck goes into manual and loses power. Happens when the truck is bobtailing AND has trailers. Speedometer stops working. PLEASE HELP!
    Two yellow check engine lights (one says CHECK)
    Red BRAKE light
    ABS light
  3. Magoo1968
    Magoo1968 Road Train Member
    2,032
    5,426
    Mar 18, 2021
    St Malo mb
    Unplug elog when it happens and see if issue goes away
    QUALITYTRUCK Thanks this.
  4. QUALITYTRUCK
    1,802
    1,763
    Jun 14, 2009
    romulus,mi
    You have a wiring issue. Most likely spot is harness just above air compressor where it is zip tied to metal bracket. Stop throwing parts/labor ($$$) at it and find a TECHNICIAN who knows how to trouble shoot properly.
  5. NorCenArk
    NorCenArk Light Load Member
    76
    35
    Mar 31, 2011
    Russellville, AR
    My truck would shut down while going down the road. Changed the PD module on firewall near steering column and problem went away.
  6. jha36660
    jha36660 Bobtail Member
    Any idea how it went away I have 2019 cascadia doing same thing spent 25k till now update cpc, Changed transmission changed few sensors.. Please let me know how it worked with you
