2016 Freightliner Cascadia 0 codes but Check Transmission light on.
Discussion in 'Ask An Owner Operator' started by Forever237, Jan 15, 2022.
  1. Forever237
    Forever237 Light Load Member
    122
    63
    May 29, 2016
    Truck has 525K miles.
    Bought it last week and when on the road, drove about 60 miles, check transmission light and HSA (Hill Start Assist) came on. Pulled over to shoulder and turned off thinking resetting would help. After turning it off and on, it beeped asking to be set on neutral to turn on the truck. Switched back and forth to Drive back to Neutral to Rev to Neutral several times didn’t help. The pressure in tanks were 130 or more so air pressure wasn’t the issue. And it is showing 0 codes in diagnostics tab.
    So towed the truck to shop. After 2 days mechanic calls and says there is nothing wrong. He hooked it up to computer and it didn’t show any codes.
    Yesterday I did loops around town and it was working fine. Decided I would go on my way home (1000 miles) when same thing happened.
    So, any advice what could it be? What to check?
  3. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    Oh the lovely world of electronics it "bites" & then it doesn't bite. It is going to take some more digging into.
  4. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
    Temp sensor on the mirror unplugged? That's an old trick to get Freightliner to idle at megas, but it puts on the light
