2016 INT pro star won’t accelerate sometimes
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ReggieLevert, Jul 27, 2021.
  1. ReggieLevert
    ReggieLevert Bobtail Member
    5
    I put it in 2nd gear to takeoff let off the clutch press the gas pedal and I get nothing. Keep stepping on the gas pedal and about 15 second later it kicks in and I can drive. This happens every so often. It’s not throwing no codes no engine lights. Not sure what could be the problem
  3. ReggieLevert
    5
    I’ve already changed the accelerator pedal sensor
  4. Lazer
    Lazer Road Train Member
    1,787
    2,831
    Jan 22, 2017
    You are saying after you completely let the clutch out, there is no movement, even before you push on the accelerator?
  5. ReggieLevert
    5
    Yes it rolls or moves forward when I let off the clutch. When I step on accelerator pedal it doesn’t drive
  6. ReggieLevert
    5
  7. ChuckMartel
    ChuckMartel Light Load Member
    160
    94
    Jan 22, 2021
    Need to have a computer hooked up when it acts up to monitor your APS sensor.
  8. ReggieLevert
    5
    I already got the APS changed
  9. ChuckMartel
    160
    94
    Jan 22, 2021
    Yes but it’d be nice to see if it’s actually seeing you press the pedal when this happens. What engine?
    Heavyd Thanks this.
