Like the title says, Volvo engineers tried to show off and over-enginiered simple stuff. I can’t hate them enough for that.
Half electronic Half mechanical air dryer:
Bought this truck almost a year ago. It was nothing but a constant money pit. And for one reason only. I can’t get its air dryer and governor work properly.
1. Fixed all the air-leaks (hoses, transmission leak, fan clutch leak (very small) was fixed). You can leave the truck for a day and pressure is around 60-90 psi the next morning.
2. Replaced air compressor.
3. Replaced Wabco air dryer (the whole freaking assembly) 4 TIMES!!!
Symptoms:
It purges air sometimes in 2 mins, sometimes every 30 seconds. Sometimes (more often than not) when I leave it to idle, it stops purging and the pressure goes over 140 psi until Safety Valve kicks in.
Also, while driving on the highway, when I glide down a hill (when glide speed goes over cruise control), air compressor pumps like hell and governor doesn’t cut it until safety valve comes to rescue. When it is back to pulling purge valve starts working. (Electronically freaking controlled governor! Who the h€ll thought it was a good idea?)
Today it wants a new air dryer ($600) because the one on it currently had already been used for 15,000 miles. And I can’t find one in dealerships.
I really want to burn it to ground but I’m a poor guy.
Anyone had this experience?
What else should I look into?
Is there a way to switch it back to primitive yet working system (like with mechanical governor, etc)?
And yes, #### You Volvo!
2016 Volvo with electronically controlled air dryer and governor. Piece of crap!
Discussion in 'Ask An Owner Operator' started by Forever237, Aug 5, 2022 at 7:00 PM.
Page 1 of 3
I would check the air line from the fan clutch again. I know you said you fixed it, but this only leaks when the engine is running. Go thru the entire line from clutch to solenoid, it’s a long piece and you may be surprised what you find.
Another Canadian driver, Siinman and Forever237 Thank this. -
Another Canadian driver Thanks this.
Did you replace the governor?
and if you did, did you actually see that the proper or ports are the right ones and you didn’t have to block a port to get it to work right?wis bang Thanks this. -
Although that electronic issue idk about.
It does sound like a leak or governor if it was a regular Volvo setup.Another Canadian driver and Forever237 Thank this. -
Page 1 of 3
