2016 Volvo with electronically controlled air dryer and governor. Piece of crap!
Discussion in 'Ask An Owner Operator' started by Forever237, Aug 5, 2022.
  1. larry2903
    larry2903 Heavy Load Member
    789
    994
    Oct 18, 2009
    On the trails
    Did you get it figured out or burn it to the ground? Enquiring minds want to know…
  3. trucker1702
    trucker1702 Bobtail Member
    Jun 25, 2023
    I have a simple solution for you. Works like there is no tomorrow.
    1.- Add an air governor. ($25).
    2.-Replace your electronically controlled air dryer with a basic mechanical one. ( $200).
    Ignore the " Air dryer malfunction" message on the dash.
    Had this issue for a year, till my air compressor burned from overworking. It was purging every 15 seconds, Eventually, it got overheated and burned all the valves and gaskets inside. Believe me, you don't want that, its a nightmare.
    Good luck!
  4. ThisIsClutch
    ThisIsClutch Bobtail Member
    Jan 31, 2024
    Has there been any updates on this? My 2017 has the same issue and it's causing plenty issues. I know they released an ecu update to fix the air volume expelled
