2017 Kensworth T680 ISX15 Automatic Turbo/RPM issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ahuizar1990, Jan 25, 2023.
  1. ahuizar1990
    ahuizar1990 Bobtail Member
    18
    4
    Jul 8, 2020
    Hello, I’m having an issue with my 2017 Kensworth T680 ISX15 with an automatic transmission. When the truck slows down and does a downshift , the RPM’s get stuck low and the turbo accelerates a lot but the RPM’s remain low and get stuck there for a second until it does the next downshift and keeps doing until it comes to a stop. When accelerating, no issues shifting except you can’t hear the turbo. But when it’s downshifting the turbo accelerates high with each downshift. It just started doing it this morning. And on top of all this, no check engine lights whatsoever. I had a mechanic look into the computer and shows no codes, checked the actuator and turbo and no issues. I’m at a lost. Thank you in advance.
  3. Tigerfishinc
    Tigerfishinc Light Load Member
    81
    138
    May 28, 2021
    It’s pretty normal for the turbo to spool up when downshifting- you should really invest in a pyrometer gauge - that will give you real time info - dynaglo is a good to go source
