2017 w900 daytime running lights
Discussion in 'Kenworth Forum' started by Lowlife70094, Jan 23, 2020.
  1. Lowlife70094
    Lowlife70094 Bobtail Member
    Maryland
    I’m looking to disable the daytime running lights. Does anybody know where and how hard it will be to do? I’ve read that it could be a pressure switch on the yellow brake valve, if so does anyone know how hard it would be to take the valve controller apart? Thank you in advance.
  3. Slowpoke KW
    Slowpoke KW Road Train Member
    1,170
    12,824
    Dec 7, 2015
    OK
    All of the trucks I’ve dealt with that had DRL’s had a fuse for them, pull the fuse and they didn’t come on any more. But I’ve never had any dealings with a 2017.
  4. booley
    booley Road Train Member
    1,420
    9,511
    Feb 16, 2008
    ^^^^^yup, should be a fuse or circuit breaker labeled DRL somewhere...
  5. bonder45
    bonder45 Road Train Member
    1,803
    5,450
    Oct 2, 2011
    Williston, ND
    MY understanding ( being its a 2017 ) is that it is computer controlled and needs to be turned off via hooking up at the dealership. ( don't quote me, it's what I've heard from the little birdies )
    spsauerland and booley Thank this.
  6. pushbroom
    pushbroom Road Train Member
    1,779
    7,311
    Sep 1, 2012
    Controlled off the CECU. Need a laptop to disable
  7. QUALITYTRUCK
    1,802
    1,763
    Jun 14, 2009
    romulus,mi
    Yup. Program is called ESA.
    spsauerland Thanks this.
