Hello, FELLOW, HARD WORKING O/Os!
I’m changing oil on my rig, 2018 Volvo VNL 780. Just hit little over 16K and wanted ask your advice what is the best oil I could use. Is it better synthetic (45k to 50k) or conventional (every 15k) and what brand?
Greatly appreciate your help!
2018 Volvo VNL 780, 16K miles. Decided to change oil. What oil best?
Discussion in 'Ask An Owner Operator' started by Forever237, Apr 16, 2018.
Page 1 of 6
Rotella T6
973k miles on my 2010 D13 (bought it with 375k)Forever237 Thanks this. -
What psi do these engines run at with warm oil at idle and as well as when driving?
D13 at idle 30 to 31psi at 70mph 60psi in the 10th gear
KB3MMX and Intothesunset Thank this. -
KB3MMX Thanks this.
I do changes at 16k to 20k. I shoot for that window. I use to do 30k oil changes but racking up the miles.
Only reason I ask is something I read on rawze website.
He made the claim shell is slightly better for lower psi engines where delo has the slight advantage for higher psi engines. They are both very good oil and are available everywhere. Just pick 1 and use it forever never change the brand or grade or anything. They all have slightly different additives in the oil and if you switch part way through the engines life cycle it can result in new wear patterns developing and thus a shorter engine life. Or that's one theory anyway.Forever237 Thanks this. -
I don't buy into any of those extended interval claims. All oil will collect some small fragments of metal wear. How long do you want that cycling through your engine? I believe in changing it at around 15,000 miles or so regardless of what oil is used. The oil filter can't be too restrictive or it won't allow it to flow quickly as needed especially at start up on a colder day. So you can't really win by changing it on long intervals.
dunchues and Forever237 Thank this.
Page 1 of 6
