2019 Cascadia pulling the pin...help!!!!
Discussion in 'Freightliner Forum' started by Kitty40, Jan 18, 2020.
  1. Kitty40
    Kitty40 Light Load Member
    55
    304
    Jun 16, 2018
    I've never been much of a Freight Shaker fan but I love this truck. It's roomy, rides smooth, has all the bells and whistles EXCEPT that fancy button in cab to release the kingpin lock. I've read the manual, backed up, pulled forward, twisted the pin while raising up, lowered air, raised air, lowered trailer, raised it etc...I cannot pull this dang pin!! I've done it a couple of times and don't know how I did it. I usually get lucky and someone is nearby that will help me. I'm tired of fighting with this thing. Does anyone know the magic trick to pull the pin with ease??
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
  4. Kitty40
    55
    304
    Jun 16, 2018
    No, I've been meaning to get one. I don't know how useful it'll be with this truck though. Seems you gotta do more than just pull the pin. Why, is it a magical pin puller lol?!
  5. Kitty40
    55
    304
    Jun 16, 2018
    18,750
    45,472
    Sep 18, 2006
    the road less travelled
    What kind of 5th wheel is it? Is the plate greased well enough?
    What kind of surface are you unhooking on?
    If the plate is greased, and the spot is level, I just pull the supply knob, back up slightly, and this one pulls, but it's not like the old one, which had a broken spring and different design.
    Kitty40 Thanks this.
  7. Kitty40
    55
    304
    Jun 16, 2018
    I'm not sure what kind of fifth wheel it is. Looks like a standard fifth wheel. I just had everything greased two weeks ago. Been on level ground each time unhooking.
  8. olddog_newtricks
    olddog_newtricks Medium Load Member
    639
    2,162
    Jun 3, 2018
    Set your trailer brakes first, back up against the pin then set the tractor brakes. That takes the pressure off . You should be able to pull the handle easily .
  9. OldeSkool
    OldeSkool Road Train Member
    1,694
    4,731
    Jul 17, 2018
    New Hampshire
    Took the words right out of my mouth. If this doesn't work you got problems and need a mechanic.
  10. Kitty40
    55
    304
    Jun 16, 2018
    Yep, done it. I've asked one of our other drivers and he says he always has a hard time with his too.
  11. TheLoadOut
    TheLoadOut Road Train Member
    2,228
    10,536
    Nov 6, 2019
    You may have to push up slightly before pulling the release arm out. It's a safety device.
    Kitty40 and OldeSkool Thank this.
