2019 Cascadia Suspension Air Gauge air line removal
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Dariokralj, Jul 13, 2020.
  1. Dariokralj
    Dariokralj Bobtail Member
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,294
    Apr 9, 2009
    Humboldt, Sk
    Probably a 'push-to-connect' fitting.
    To install the plastic hose just push it in. Done.
    To remove it, you push in on the plastic collar that immediately surrounds the air line. Then gently pull on the air line.
    A small wrench sideways can be used to slide over the air line to push on the collar, I find it helps to push in on the air line initially at the same time.
    Dariokralj Thanks this.
  4. Dariokralj
    Thank you.
    I will try and let you know.
    Thanks again.
  5. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    push line in first. then push collar in. the hold collar in and pull line out
