2019 LT with A26. SPN: 3216 FMI:10 Nox sensor. Where is it?
Discussion in 'International Forum' started by kemosabi49, Jul 16, 2022.
  1. kemosabi49
    10,535
    45,040
    Jan 13, 2013
    SW Arkansas
    Just like the title says. Shop says to get at it they have to pull both seats, the floorboards and the doghouse to get at the sensor on the rear of the motor. True? Anybody know?
    @Goodysnap @nasriza Any ideas? Company truck but I drive it. Check engine light with this code comes on. Then goes off for from 10 to 200 miles, then back on again. Over and over.
  3. Goodysnap
    Goodysnap Road Train Member
    3,710
    9,005
    Jul 12, 2017
    Sorry, not familiar with that chassis or engine.
    kemosabi49 Thanks this.
  4. Heavyd
    Heavyd Road Train Member
    7,764
    6,203
    Feb 4, 2009
    The inlet Nox sensor is mounted at the rear of the engine. Most trucks you are able to turn the steer wheels all the way to the right, remove the left side inner fender, squeeze up in there and reach up to unbolt the sensor. There are a couple of zip ties at the back to cut too. Then turn the wheels to the left, remove the right side inner fender and you reach the rest of the zip ties and remove the sensor end from the outlet pipe.
    Reason for edit: spelling
  5. kemosabi49
    10,535
    45,040
    Jan 13, 2013
    SW Arkansas
    Thanks. I'll show this to the mechanic.
    Heavyd Thanks this.
