2019 Volvo VNL 860 Stereo No Sound
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by arbiternal, Jun 2, 2020.
  1. arbiternal
    arbiternal Bobtail Member
    Jun 2, 2020
    Hello folks,
    Have a silly little problem, car turns on fine, there's power to the stereo/radio unit, but there's no sound coming through, tried FM, AM, and USB, but no luck. Is there a easy fix for this?
    Thanks
    Trucking Jobs in 30 seconds
  3. PE_T
    PE_T Road Train Member
    Try your fuse box.
    arbiternal Thanks this.
  4. arbiternal
    Jun 2, 2020
    Thank you for the reply, I've checked the radio related fuses since then, but have not been able to find faulty ones, maybe I'm looking at the wrong fuses, maybe it's some other issue.
    PE_T Thanks this.
  5. boneebone
    boneebone Road Train Member
    2,094
    1,997
    Mar 13, 2009
    It could be a defective amplifier, check the cabinet in the front upper right cubby hole in the corner, there’s usually an amplifier in there.
  6. arbiternal
    Jun 2, 2020
    Thank you for the reply. Not sure how to check if it's defective or not, but we'll figure something out!
  • Draft saved Draft deleted
