2020 T680 heater fan noise
Discussion in 'Kenworth Forum' started by drewfarmsllc, Mar 12, 2025.
  1. drewfarmsllc
    drewfarmsllc Light Load Member
    84
    32
    Oct 18, 2008
    South Carolina
    My 2020 t680 when i press the auto button for temp the fan will speed up and slow down to keep cabin temp at desired temp. Mine does that but when the fan needs to turn fast it sounds like a jet engine taking off. Trucks got 590 on odometer and it just started several months ago. I took glove box out and couldnt find anything that seemed loose.
    Has anyone found an answer to this?
  3. Goodysnap
    Goodysnap Road Train Member
    3,791
    9,229
    Jul 12, 2017
    The blower motor wheel will get a fine dust build up on the wheel over time and it will be off balance and vibrate. Pull the blower motor and clean the wheel of dust and reinstall. New HVAC filters need to go in too.
    If the issue persists replace the blower motor with new.
    drewfarmsllc Thanks this.
  4. drewfarmsllc
    84
    32
    Oct 18, 2008
    South Carolina
    Thank you. Will check this
