2022 Kenworth t680 - ticking sound with engine off
Discussion in 'Kenworth Forum' started by OTRMatt, Apr 14, 2025.
  1. OTRMatt
    OTRMatt Bobtail Member
    4
    Apr 14, 2025
    the engine is OFF, this ticking sound happens frequently. No pattern as to when, except that my engine is off. When sitting inside, it sounds like the sound is coming from somewhere in line with my steer axle.
    I would love if someone knew what this is, if it can even be identified by sound alone.
    It may or may not be related, but my bunk heater stopped working as well. When I try to turn it on, it will start up, but after a minute or two the screen flashes and factory resets. I say it may be related because it does the flash/reset right when one of those loud clicks happen.
    D.Tibbitt Thanks this.
  3. D.Tibbitt
    147,260
    I don't think that's your bunk heater... the fuel pump does click but not that loud... usually if the bunk heater will start but then reset after a couple minutes , it's because it is not igniting the fuel...
    Not sure what those banging sound could be... sounds like something banging against eachother
  4. OTRMatt
    4
    Apr 14, 2025
    I'm pretty sure it's igniting, initially, at least, because for that first minute that it does come on, it blows hot.
  5. JB7
    JB7 Heavy Load Member
    750
    1,149
    Dec 13, 2022
    Laurel, MD
    Do you have an auto-shift transmission? I would check to see if the clutch is activating or if the top of the trans is trying to shift into gear.
    OTRMatt Thanks this.
  6. OTRMatt
    4
    Apr 14, 2025
    I do have an auto, yes. PACCAR engine, if that makes any difference. I also had someone else suggest it was transmission related, I'll look into that, thanks.
  7. D.Tibbitt
    147,260
    How bad does it smoke ? I've had the same problem with the bunk heater and it will start up and blow hot and then it will die and reset itself. Almost always an ignitor problem or fuel pump problem
  8. OTRMatt
    4
    Apr 14, 2025
    It doesn't smoke. It simply shuts off. I've had other trucks where the bunk heater wouldn't ignite, those DO smoke something terrible, but that's not happening. I presumed it's a wiring issue, but then I'm just a driver, not a mechanic
    It's likely unrelated to the clicking issue, but the consistent timing of it has me suspicious.
