2022 Kenworth w900L Headlamp Issue
Discussion in 'Kenworth Forum' started by hpeters, Apr 30, 2023.
  1. hpeters
    hpeters Bobtail Member
    8
    4
    Jul 5, 2022
    I have a 2022 Kenworth w900l. Left low beam does now come on, right side works. When high beams are switched on the left low beam will work. I am not getting power to the left low beam wire. Checked all fuses and they are all good. All input power going to the chassis node have power however the output pin for the left low beam at chassis node doesn’t send out power. On dash code reads Chas. Node Pwr. Input Faulty check fuse and low beam lamp fault detected. Truck only has 200,000 km. Has anyone had this issue? Have you replaced the chassis node and it fixed the problem?
  3. AModelCat
    158,185
    I think the low beam light is a dual filament bulb if I'm remembering it right. One wire is low beam, other wire sends power when high beam is activated, 3rd wire ground.
    Have you tried a new headlight? Some of these newer units with cab ECUs won't power up a circuit if it detects its open (ie unplugged or burned bulb).
    Oxbow and JB7 Thank this.
  4. JB7
    JB7 Heavy Load Member
    749
    1,148
    Dec 13, 2022
    Laurel, MD
    Exactly, replace the headlight. "On dash code reads Chas. Node Pwr. Input Faulty check fuse and low beam lamp fault detected." That should work but if it does not then move on from there.
    Oxbow and AModelCat Thank this.
  5. hpeters
    8
    4
    Jul 5, 2022
    I did replace all high and low beam lights and I still have that same issue the left low beam will go out when I only have low beams on. I ordered a new chassis node so I’m hoping that will fix the issue
  6. AModelCat
    158,185
    I'd have isolated the left low beam wire at the node and powered it up with a fused jumper lead to confirm the wiring was good and also checked that the headlight ground was good before throwing money at it. No idea if Paccar grounds the headlights to the frame or if ground comes back to the node though. Have to take that into account before sending power down circuits with computers in them.
    Oxbow Thanks this.
  7. JB7
    749
    1,148
    Dec 13, 2022
    Laurel, MD
    The attached diagram shows the headlight ground goes to a stud on the inside of the frame rail (circled in red). Diagram not for exact same year. Then there are 3 harnesses that go from the node to the headlight. There was another thread on here recently (about March 11) where the left turn indicator had a problem.
    Interesting that the message states "Input fault" but you say that all the inputs are good. Circuit needs to be under load, it can be ok when unloaded but not ok with a load. Which is why a good tech will use a bulb to test the circuit under load.
  8. hpeters
    8
    4
    Jul 5, 2022
    Thanks. I’ll double check the grounds and the wire going from node to headlamp. If all fails I got a new node coming and have Kenworth look at it as well before I plug the new node in.
  9. hpeters
    8
    4
    Jul 5, 2022
    It ended up being the chassis node. Check all wires over couple times and then decided to plug the new chassis node in and it all works now. Bit of an expensive repair.
    JB7 Thanks this.
