2023 Peterbilt 579 heater blowing cold air.
Discussion in 'Peterbilt Forum' started by bentstrider83, Feb 27, 2025.
  1. bentstrider83
    bentstrider83 Road Train Member
    1,726
    1,645
    Dec 26, 2011
    Portales, NM
    Company truck and had this issue fixed at a Peterbilt dealer in Amarillo back in December. Worked fine until I had to make a personal vehicle trip out to CA and back last week. It's now totally freezing in the front again, while the sleeper heater thankfully still works.
    Any easy way to remedy this before telling the company it broke again? I don't really want to be sidelined while it's at the shop again. Company doesn't have any loaner trucks to spare.
  3. Long FLD
    Long FLD Road Train Member
    12,438
    51,569
    Mar 4, 2015
    Try unhooking the ground on your battery for a few minutes and see if that resets the computer. Other than that the dealer will probably have to hook up to it and see what’s going on. Could be as simple as needing a software update or you could have actual component failure. What did they say the problem was in December?
    Concorde and bentstrider83 Thank this.
  4. Goodysnap
    Goodysnap Road Train Member
    3,744
    9,105
    Jul 12, 2017
    Most commonly needs a temp blend door actuator. High failure rate.
    Concorde Thanks this.
  5. Concorde
    Concorde Road Train Member
    5,252
    18,363
    Jun 29, 2016
    West Melbourne Florida
    Amazing how many problems I’ve solved by using the battery disconnect.. I’ve had a similar problem as @bentstrider83 but it was the sleeper blowing cold. Now if I could just figure out why fourth gear ( fan speed 4) ain’t a workin..
    Mines a 2023 also..389 but I’m sure everything is the same.
    Long FLD Thanks this.
  6. NorthEastTrucker
    NorthEastTrucker Heavy Load Member
    969
    1,815
    Sep 21, 2019
    I had the same issue when I bought my 2023 Pete 567.
    Probably not the coolant but check anyways. Then when starting the truck, hold down your thermostat gauge and vent control for 5 seconds. Yes, it sounds dumb but worked for my truck everytime until it reset to automatically blow heat. Once and again, it will blew cold air espeically here in Canada being minus 10 Fahrenheit at times is a real issue.
  7. bentstrider83
    1,726
    1,645
    Dec 26, 2011
    Portales, NM
    All sounds good. I'll definitely try the battery thing. Of course it could very well be that since I was having battery issues when I tried starting it on Sunday morning.
    @LongFLD It was cat food that fell into the vents according to the Peterbilt shop. My own up and I'm getting payroll deducted for it. Punch to the gut regardless and leaves a bad taste in my mouth. But that's a debate for another thread.
  8. FLHT
    FLHT Road Train Member
    1,407
    2,480
    Aug 2, 2014
    Are your heater hoses hot where they go thru the fire wall ?
    If they are you got heat to the heater core.
    The fresh air vent door may be stuck open.
    Duck tape up the fresh air vent on outside of cab.
    You should have heat now.
    Actuator's may be stuck.
  9. bentstrider83
    1,726
    1,645
    Dec 26, 2011
    Portales, NM
    The battery disconnect/reconnect done did it!!!
    Long FLD and Concorde Thank this.
  10. Concorde
    5,252
    18,363
    Jun 29, 2016
    Glad to hear it.
    bentstrider83 Thanks this.
  11. bentstrider83
    1,726
    1,645
    Dec 26, 2011
    Portales, NM
    My 200 piece Kobalt toolkit gets the joj done!!
