214 T680 blinkers not working in headlight assembly.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by insanityeight, Jan 20, 2021.
  1. insanityeight
    insanityeight Light Load Member
    287
    111
    Jul 26, 2013
    birmingham al
    2014 t680. Just recently happened. All blinkers work except the ones in headlight assembly. Bulbs and fuses look good. Anyone know where the harness runs to for power and ground or anything that would help figure this out. Do possibly have a ground problem as sometimes at night I see the blinkers on side of fender by headlight lightly illuminate when interior cab lights are on and when the cab lights go out it will stop, and one or two of my gauge lights will dim down sometimes. Thanks in advance.
  3. DJMech
    DJMech Bobtail Member
    20
    12
    Jan 23, 2021
    For a T680, usually the harness that feeds both headlights are ran up driver side inside the frame and then branch off to both sides in front of the radiator but behind the hood.
    Thanks, DJ
    Goodysnap and bzinger Thank this.
  4. bzinger
    bzinger Road Train Member
    16,613
    65,929
    Dec 10, 2014
    omaha , ne
    The 680s in my fleet are famous for harness issues at the headlights.
  5. DJMech
    20
    12
    Jan 23, 2021
    Yeah, for some reason they always forget to ziptie it to the hood so it usually just rubs through a wire or 2. Seen one melted once!
    bzinger Thanks this.
  6. insanityeight
    287
    111
    Jul 26, 2013
    birmingham al
    Thanks. I quickly figured that much out but Im curious as to where it goes for power, such as the firewall or somewhere else. Where does it feed from?
  7. DJMech
    20
    12
    Jan 23, 2021
    gotcha, usually it feeds up the frame rail then into the main wiring harness that then goes into the truck then to the fuse boxes, either the one on the firewall outside or inside kick panel
    insanityeight Thanks this.
