24.5 11R to 24.5 lp tires on pete 389
Discussion in 'Peterbilt Forum' started by Black389, Oct 5, 2018.
  1. Black389
    Black389 Light Load Member
    181
    42
    Dec 1, 2016
    Indy
    Whats up people. Not sure if im asking this question in the right place, but here it goes.
    I have a 2015 pete 389 with 3:55 rear with 18 speed. When i bought this truck brand new it had Bridgestone 24.5 11r all the way. I just bought a new Bfgoodrich tires in 24.5 lp, and now my speedometer is off by 5-6 mph. My rpm is too high at 70mph (1500+) before i could be going 75+ with rpms around 1550. It slows down a lot on hills. Is there anything i can do or is my best bet to buy another set of 8 drive tires? One guy told me i can change the tire size in the ecm but wont that only fix my speedometer? Im just confused my friend has same truck (motor, ratio, trans) and he has 22.5 lp and hes just fine with his rpms, he can be running 80mph in NV and still have his rpms under 1700.
    Really appreciate it!
  3. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    8 new tall tires would be the easiest if you're looking to get back to moving right along at low rpms. If you just want your speedometer fixed they should be able to do that at most any shop I think.
    Black389 Thanks this.
  4. Black389
    181
    42
    Dec 1, 2016
    Indy
    #### it! Have to spend another 4k on tires now. Its also drinking fuel like crazy
  5. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Just put talls back on her and find somebody to buy your lopros for 500 bucks less than you played for them, somebody will buy them. That's a nice looking truck.
  6. Cat sdp
    Cat sdp . .
    21,059
    73,863
    Apr 8, 2012
    Orion's Belt
    Something is different on your buddies truck....... there’s no way 22.5s would run the same as your old 24.5s .....
    Something has to be spec’d differently.
    pushbroom, Oxbow and Ruthless Thank this.
  7. jake744
    jake744 Light Load Member
    126
    138
    Dec 27, 2017
    When I ordered my 389 I got tall 24.5's and its 3.55. If I got low 24.5's it would have been 3.36 and 22.5 low was 3.25. I would say change to 3.36 gears or go back to tall 24.5's.
  8. Black389
    181
    42
    Dec 1, 2016
    Indy
    What do i need all in parts,What is the expense to change gears? I really wanted to stay with 24.5 lp.
  9. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Get good used parts and I don't think it would cost more than 4 grand to maybe 5 but I'm really not sure on that.
  10. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    New tires may use more fuel what's the rolling resistance
    magoo68 Thanks this.
  11. Ruthless
    Ruthless Road Train Member
    9,007
    89,025
    Aug 28, 2010
    The City.
    More than a set of tires. Last front chunk I got (Eaton genuine reman) was $3800 plus labor. Rear rear was going for $2350 at that time.
    SAR, Black389 and Oxbow Thank this.
