24.5lp vs 11r22.5
Discussion in 'Trucks [ Eighteen Wheelers ]' started by NFDDJS, Sep 3, 2012.
  1. NFDDJS
    NFDDJS Light Load Member
    267
    37
    Jul 8, 2012
    New Hampshire
    So 24.5LP or 11R22.5, why would you go one way or the other???
  3. 25(2)+2
    18,749
    45,407
    Sep 18, 2006
    the road less travelled
    Load rating should be higher for the 11r, but rolling resistance is also higher. Availability of each varies in different areas. I'd say the balloon tires are better off the pavement , too, but there isn't a great deal of difference.
  4. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    i've noticed that the low 24 spare i have for the trailer is the same size as the high 22 spare i have for the truck. both sitting on the deck.
  5. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    I would say 11r22.5's are better. Certainly nicer riding, plus they're much more available.
  6. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I never had figured out which is better overall. I went from low pro 22.5 to standard 22.5 the 11r22.5 are the same height as the low pro 24.5. the lower pro gives less r.r. but with the bigger tire you will have the rpm's lower at the same m.p.h. so less rpm's, save fuel. my rpm's are at 1500 when I am at 62 m.p.h. with the low pro's it would be 1600 this is theory of course. still not sure which is better on fuel. the only reason I went to the taller tire, was my truck's top speed was 68 @ 1850 the taller tire gave me more top end.
  7. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    I am not so sure about much more readily available. Maybe in certain parts of the country. Since the vast majority of trucks and trailers have LP 22.5 on them, I would tend to think that LP 22.5's are more readily available. The market supplies what the most demand is.
  8. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,539
    Jul 30, 2009
    Mapleton Depot,PA
    If you need the weight capacity of the 11R you could go to load range H on the 24.5LP, but they are even harder to find. That's what I put on my steer axle as I was often too close to the limit for G.
  9. w900
    w900 Light Load Member
    83
    27
    Mar 25, 2009
    Carlisle,Pa
    If you run virgin tires check with your tire shop about casing values. The tire shop I use pay double for 11r22.5 compared to 24.5lp.
  10. k whopper
    k whopper Light Load Member
    100
    13
    Sep 9, 2011
    milledgeville ga
    in my neck of the woods the middle ga area there are plenty of lp22.5 and 11r22.5 around a used 11r24.5 is like gold
    lotus6six Thanks this.
  11. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    Big tire looks cooler than baby wheels.
    DrtyDiesel Thanks this.
