Hi everyone I was just wondering if anyone can confirm or knew if I had one of these and hooked it to 12votl it would drop to 6 volt ? Or would it hold the voltage as close to 12 as it could ?
24volt to 12volt converter question
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by tonyhatchetman, Oct 6, 2012.
why are you trying to drop to 6 volts? and where does 24 volts come into the question?
you need a transformer. -
I am wanting charge a 6 volt battery with my 12volt system , the converters ive found are 24v in and 12v out can't find a 12in 6 out so that's why I want to know if putting 12 in a 24 v unit will still cut the voltage in half .
No it won't cut it in half.
Do you have an inverter. If you do I would buy this maintainer charger for 12V or 6V. It uses less than 200 watts at 1.5 amps.
I use it to maintain my boat and riding mower batteries in the winter. It works great. It's real small too.
http://www.walmart.com/ip/Schumacher-XM1-5-Maintainer-1.5-Amp/15140193
This one is even smaller for 6V... uses about 120 watts
http://www.walmart.com/ip/Schumache...rger-with-Wall-Plug/15167359?findingMethod=rr
Remember charging requires ventilation. I wouldn't be doing it inside the truck.
