2nd gear has NO power.
Discussion in 'International Forum' started by -insert name-, Jul 29, 2012.
  1. -insert name-
    -insert name- ATM squishier
    1,293
    633
    Jul 12, 2012
    SOMEWHERE
    '12 Prostar with the Navistar 13. Not even over 4,000 and I'm having problems. 1st gear, alright, no problems. Put it in 2nd and had no pull. Stoped, tried again. Still no pull. Started over again, this time using the clutch. Clutched out, rev, clutch in. No pull. Rolled up to the next stop light, started off in third, BINGO. Had it back. So, taking off from the fuel island I tried 2nd again. Still not pulling. Rolled over to the McD, unhooked, tried it at the exit. No pull still. At this point I'm about to call International and see what the problem is. Hook back up and go in to eat. Whats the deal?
  3. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    Just the one gear?
    Wierd!
    Did you try cussing it out in French? It might not be bi-lingual!!!!!:biggrin_2552:
  4. -insert name-
    1,293
    633
    Jul 12, 2012
    SOMEWHERE
    Just the one gear, got a time set to put it in the shop Thursday.
    French? um... bonjour?
  5. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    OK...now that you've been introduced...put her in time-out so she can get a spanking!!!!
  6. -insert name-
    1,293
    633
    Jul 12, 2012
    SOMEWHERE
  7. Shaggy76
    Shaggy76 Heavy Load Member
    831
    307
    Feb 22, 2012
    Orlando, FL
    What's the mileage? Still under warranty? You might be getting a rebuild.
  8. -insert name-
    1,293
    633
    Jul 12, 2012
    SOMEWHERE
    The word warranty.... I'll get this: "It's nothing."
  9. Heavyd
    Heavyd Road Train Member
    7,809
    6,260
    Feb 4, 2009
    So your saying in second the truck won't move? If second won't move the truck, then try the same gear in high range and see if it still won't move. Anyway, it sounds like something is broken in the trans and time for a visit to the dealer.
  10. -insert name-
    1,293
    633
    Jul 12, 2012
    SOMEWHERE
    Set to be thrown in the shop Thursday morning, meaning I need to make sure I can be there Wednesday night. No, it won't move in that gear. It will rev but won't move.
  11. snowwy
    snowwy Road Train Member
    20,591
    13,310
    Jul 6, 2009
    i drove a mack dump truck once. super 10. that when put in reverse. it totally locked up. not even forward would work. the truck had to be pulled backwards in neutral to get it to unlock and drive forward.
    company drove it to the transmission shop for rebuild. just didn't use reverse.
    got taught a lesson in transmissions that day. if it locks up. either forward or back. the trick to unlocking is pull the truck in the direction you drive to lock it. so if it locks up going forward. your only option is drive in reverse. LOL.
    like the above post mentioned. if second dont' work. the top gear in second probably also isn't working.
