2ws 40pin??
Discussion in 'Trucks [ Eighteen Wheelers ]' started by StarcarPA, Mar 11, 2014.
  1. StarcarPA
    StarcarPA Bobtail Member
    32
    Mar 9, 2014
    I bought a frieghtliner with 2ws emodel motor. It is a 40 pin ECM . My question is do you think it has the correct file in the computer since its suppose to be 70 pin? If not is there anyone who can flash it besides cat
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    How do you know for sure it's actually a 2ws. Are you just going off the tag on spacer plate under the valve cover?? Maybe some one switched engines. And no, you can not put a 70 pin file in a 40 pin ECM. You can't just put a 40in ECM on a 2ws as it has two timing sensors and a 40 pin ECM is setup for just a cam position or speed sensor. You should look at serial # on the block to know for sure what you got there.
  4. StarcarPA
    32
    Mar 9, 2014
    It's a 2ws. The sensors were changed on the front of the motor
  5. underpsi
    underpsi Road Train Member
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
    Could have a 5EK file, 6TS, 1LW or a 5DS
  6. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    I would be more interested in why all that was done to the engine than what file is in the ECM, I would be surprised if cat would even flash it.
  7. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Reguardless , your never going to get a 2ws file into your 40 pin ECM. Not compatible.
  8. ROBSREDFORD
    ROBSREDFORD Light Load Member
    266
    139
    Sep 2, 2008
    MIDLAND, NC
    IMHO the 40 pin stock files are better anyway and the 2ws block is strong. In essence you have a 1lw now. Put a pre low nox file in and ride
