2ws starting problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by peterbilt1999, Mar 24, 2018.
  1. peterbilt1999
    peterbilt1999 Bobtail Member
    21
    14
    Mar 24, 2018
    been having problems all winter starting and its plugged in acts like it is losing prime.one day it starts the next it doesn't .sits for 3or 4 days and starts next time it doesn't every thing replace seems to fix it then in a week its hasn't. replaced fuel lines ,fuel pump, check valve, removed and plugged fuel filter restriction line to guage, it doesn't act like it is being told it can start when cranking even with ether. replaced cam and crank sensors crank sensor had oil leaking through was sure that was it. still turn over till your sure it won't turn over any more if you stop cranking and it starts and yes it gets cooled off several times when trying to start 1,250,000 and never been opened new rods and mains at 1,100,000 and they were fine. oil changed every 15,000 with a gallon of lucas and no blowbye and doesn' use any oil oil analysis comes back all good. anybody got any ideas it runs good and gets 6.8mpg in winter flatbed and light oneway freight home at night
  3. Goodysnap
    Goodysnap Road Train Member
    3,716
    9,022
    Jul 12, 2017
    Was there a question in there? JK .....givin you crap
    I would start with shaking down the wiring. Load test the powers and grounds to the ECM. Or maybe the ECM is starting to crap out. My bet is on wiring.
  4. peterbilt1999
    21
    14
    Mar 24, 2018
    after it starts its good till the next day or next week it will start all day no problem. will load test wires and see what happens. ecm going bad only know with a new one or can they rebuild it??
  5. Goodysnap
    3,716
    9,022
    Jul 12, 2017
    Usually ecm failures are not intermittent, once they are done thats it, they don't come back. They are reman exchange.
  6. Oxbow
    Oxbow Road Train Member
    12,816
    132,659
    Nov 24, 2015
    After it has been shut off for quite awhile, check to see if the alternator is warm before starting it. The alternator can charge fine while running, but will draw while shut off if it has a bad diode.
    One of the easy things do begin with in the process of elimination.
    Broke Down 69 and SAR Thank this.
  7. peterbilt1999
    21
    14
    Mar 24, 2018
    will do more checking in the morning me and the mechnics are out of ideas
    Oxbow Thanks this.
  8. peterbilt1999
    21
    14
    Mar 24, 2018
    thanks for the replys
    Oxbow Thanks this.
  9. spsauerland
    spsauerland Road Train Member
    4,296
    10,887
    May 31, 2010
    West Harrison, In
    With a 2WS, I am guessing we are talking about your username a1999 Peterbilt. When you start it or fails to start, pay attention to check engine light and tach. Pretty sure a 99 tach will be ECM controlled. The check engine light should come on @ key on and go out in around ten seconds. This tells you ECM is powering up and no active faults. Next crank it. If fails to start, watch the tach. If showing cranking RPM at least 200, your speed/timing sensors are good and you have more of a fuel problem. Needs at least 150 RPM to start. Does it smoke excessive for a couple seconds when it does finally start?
    SAR, Oxbow, pushbroom and 1 other person Thank this.
  10. peterbilt1999
    21
    14
    Mar 24, 2018
    no excessive smoking at start they already tested the ecm wiring and when running moving the wiring around gets no result and water doesn't change anything as in when raining. still trying to figure it out help!!!!!!!!!!!
  11. DieselTech_Aus
    DieselTech_Aus Light Load Member
    274
    309
    Dec 20, 2017
    WA
    I would do the following.
    in the morning when you know its not going to start, roll the bonnet over and grab the fuel hand primer pump. pump it until when its firm and on the down stroke you hear a squeak which it the fuel going over relief and out return.
    go straight to the cab turn the key to on. wait until the check engine light has come on and gone off again then try to start.
    if it starts straight up your problem is in the fuel system. if not its elsewhere
    fuel can bleed back to tank or bleed of prime through several places.
    • the primer pump
    • the return check valve
    • the poppet valve in transfer pump
    • the primer pump check valve in filter housing
    • the inner seal and back up ring on the filter bleed plug also in the filter housing
    • injector bodies
    • injector orings.
    • injector tips
    if it still doesn't start after you have pumped the primer before trying to start it when you know it will fault then you'll need to view some data with ET when fault is present
    Oxbow Thanks this.
