3.25 rearends 9 speed Trans Converted to 13 speed. Want to upgrade
Discussion in 'Ask An Owner Operator' started by Brandon0928, Nov 16, 2022.
  1. Brandon0928
    Brandon0928 Light Load Member
    184
    105
    May 14, 2022
    Got a 2018 579 x15 cummins 500hp Efficiency Series . It has a 9 speed trans that was converted to 13 speed. Has 3.25 rearends. I want to upgrade to a 18 speed. What would be the best rearends to go along with it ? Best clutch as well ? I drive mainly in the Midwest ( Iowa, Nebraska, South Dakota ) then during spring and fall go out west ( Montana ) . I haul cattle so typically loads are pretty heavy . Pulling a quad axle trailer . What would be the ideal set up here?
  3. Mnmover99
    Mnmover99 Light Load Member
    248
    343
    Oct 22, 2022
    Just drive what you have and wear it out, then upgrade when you buy the next truck. Unless a major part needs repairing, just drive what you have. The 18 speed only allows you to split the gears on the low side.
    armo and Last Call Thank this.
  4. Lazer
    Lazer Road Train Member
    1,803
    2,879
    Jan 22, 2017
    You sure about that? If I recall correctly, the 18sp. at my previous employer I could split every gear, in both ranges.
    NightWind Thanks this.
  5. Brandon0928
    184
    105
    May 14, 2022
    That’s exactly my plan. Except I’m planning on keeping this truck for a long time. Every truck I’ve owned in the past had an 18 speed and it was nice to have. Never needed it around the Midwest really other than a few times at places I loaded. But it’s sure nice to have when your 100k plus and got a steep hill to climb and you gotta start at 0 at the bottom of it lol. Just figuring out what would the absolute best set up
  6. Brandon0928
    184
    105
    May 14, 2022
    I think what he meant was the only difference between 13 and 18 is that you can also split on the low side. Compared to a 13 you can only split the high side
  7. HoundDog7
    HoundDog7 Light Load Member
    185
    957
    Oct 7, 2022
    Kansas
    X15 with a nice tune set at 2050 torque, 2050 eaton easy pedal clutch, rear gears won't be really necessary, but if your dead set on it I'd say a set of 3:55 gears. As far as transmissions go, if an 18 is what you're after, get a RTLO22918B. Depending on tire size that combo will get you around 80mph at 1700 rpms and still pull nice in my opinion.
    Jubal Early Times and Last Call Thank this.
  8. Brandon0928
    184
    105
    May 14, 2022
    I’d like to run 22.5 low pros. But I think I’d like to have it where when running at 65 rpm’s are around 1700. Same with 55mph. Everything I’ve read are these engines need to be run at higher rpm’s. I’ve ran mostly cats and kinda always stayed around 1500rpm. So I have a tough time trying to stay at 1700 when I’ve pretty much run 1500rpm for 10 years. Lol
  9. HoundDog7
    185
    957
    Oct 7, 2022
    Kansas
    If you're wanting to go that small of rubber, I'd leave the 3:25 gears in it then. With lp24.5 and 3:55 and 18 speed, I'm right about 1500rpm at 70mph. If I split top gear and come outta top overdrive, I'm around 1700rpm at 70.
    Jubal Early Times and Opendeckin Thank this.
  10. Brandon0928
    184
    105
    May 14, 2022
    Do you know what I’d have to upgrade to get 2050 torque ? I know someone with the x15 performance series the shop was able to do 605hp and 2050 torque. But when I talked with the shop with the efficiency series I can only do 505hp and I forgot what they said for the torque
  11. AModelCat
    160,529
    Probably have to more or less rebuild the engine. I seem to recall the Performance X15 runs a lower compression ratio than the Efficiency X15.
    armo, Crude Truckin' and Siinman Thank this.
