3:36 vs 3:91
Discussion in 'Ask An Owner Operator' started by Randhawa.56, Jan 5, 2022.
  1. Randhawa.56
    Randhawa.56 Bobtail Member
    9
    6
    Jun 4, 2021
    Hello truckers, I got a cascadia 2016
    Dd16 500hp 13 spd 22.5 tires And 3:91 gear ratio. The mpg im getting is 4.9 on 69-72mph
    I wanna know if i will chage gear ratio to 3:36 how much difference it will make.
    Thank you
  3. Magoo1968
    Magoo1968 Road Train Member
    2,032
    5,426
    Mar 18, 2021
    St Malo mb
    It should improve dramatically 3.91 is a heavy haul gear. Dd16 is a low rpm motor
    Brettj3876, Bean Jr. and Randhawa.56 Thank this.
  4. Pamela1990
    Pamela1990 Road Train Member
    1,820
    10,716
    Nov 7, 2021
    B.C. Canada
    How much do you weigh when loaded?
    Mountainous terrain, or flat lands?
  5. Randhawa.56
    9
    6
    Jun 4, 2021
    40000lbs on flats
    Magoo1968 and Pamela1990 Thank this.
  6. Pamela1990
    1,820
    10,716
    Nov 7, 2021
    B.C. Canada
    Definitely use some taller gears then.
    Bean Jr. Thanks this.
  7. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    You may be able to switch to taller tires or wheels instead of changing gears depending on how far gone you're current tires are.
    Brettj3876 and Pamela1990 Thank this.
  8. AModelCat
    158,964
    Cost vs reward.
    How long will it take to break even on the cost of re-gearing?
    Last Call, Brettj3876 and Pamela1990 Thank this.
  9. dirthaller
    dirthaller Road Train Member
    1,071
    12,215
    Sep 22, 2011
    Coloratah
    Interesting that you chose 3.36 to compare to because 3.36 is exactly 1/2 gear above 3.91. You’ll be running the exact same speed at the exact same rpm only now your transmission will be in 12th gear instead of 13th. So basically you’ll be adding another overdrive gear. If you want to burn clutches up, you can go to 2.85 gears and be exactly a whole gear above 3.91 (basically same speed/rpm in 11th gear vs 13th)
    Brettj3876 and Magoo1968 Thank this.
  10. abyliks
    abyliks Road Train Member
    3,885
    9,080
    May 2, 2010
    ludlow MA
    If you are on low pro rubber I would try and go to an 11r or 12r first.
    taller gears are great until you go to take off loaded, even my 3.55s are a smidge to tall, 3.91 are about a perfect highway gears if you are running 11r24.5
    ProfessionalNoticer Thanks this.
  11. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,058
    Nov 18, 2014
    Land of local
    Talk about overkill for flat land and legal weights Lol
    Magoo1968 Thanks this.
