Just wanted your opinion since I am kinda new to this . I am looking at two trucks - both Freightliners and both have the 12.7 Detroits in them . One has a 3.73 ratio and a 13 speed- the other has a 2.89 and a 9 speed . I will be driving all 47 states ( California excluded ) . I will be hauling very light but balky loads ( campers ) and I am probobly the one that you complain about driving WAY to slow ( at least I am always in the slow lane - LOL ) . What I am trying to accomplish is excellent fuel economy . With the info that I have told you , do you think that there will be a major MPG difference between the two trucks ?? Again - light but balky loads and slow driving . And if you had to guess - how much of a difference ?? THANK YOU in advance !!
3.73 vs 2.89 ratio with a Detroit ??
Discussion in 'Ask An Owner Operator' started by jeffman164, Jan 21, 2013.
Page 1 of 3
go with the 13speed.......
I'm guessing 2.89 with a 9 speed is probably a direct drive 9 speed i think i would go for the 13 though for drive-ability.
according to the calcutlations they are about the same final depending on drive tires. by final i am not talking of the tranny talking at the wheels tranny rears and tire. but if it where me i would take the 13 speed since it is a 13 and run it a while maybe drop some 3:55 or alittle smaller would got to low though you will be dropping top gears to maintaine highway speeds and some rpms as 12.7 do best around 1450 - 1600 rpm when you get them down around 1400 you will hear motor rattle. i think 13 speed with 3:55 with 11r22.5 or LP24.5s would give you good all around results. since it seems you will be light you dont need alot of power but you will have ok power for pulling the long big hills still beware alot of cummins guys say run low rpms...newer cummins are made to 12.7 detroit aint. to get best results everything needs to match motor tranny rears and tires. and matched to what you are doing...thats the reason i gave what i gave now for me that would not work i would need the 3:73 as i am starting flatbed again and will be heavy hauling so i need more power. the less a motor works the better the MPG
i cant picture anyone specing a truck with a overdrive 9 speed with 2.89's and a 12.7 of course i'm sure stranger things have happened.
Ruthless Thanks this. -
That one with the 9 spd and 2.89 sounds like what Swift used to spec in a lot of their road trucks. Those 9's were 9/13 convertable trannys. Running a 13 with the 2.89 wouldn't be too bad. Just use single overdrive. If you really wanted to step out, then go to double over. Either way, it would work. And if it is one of those convertable tranny's, have it converted as part of any negotiated deal. Not that expensive. Then it would be just a matter of which truck you like best.
The one that already has a 13 and 3.73 rears is not a bad choice, especially if you are one who doesn't run like his hair is on fire. That one, run at around 60 mph would be a solid performer and should get good mpg. The engine would be turning 1450 rpm on low pro 22.5 rubber or 1400 rpm on low pro 24.5 rubber at 60 mph. My 12.7 seems to have a real nice balance of power and economy at 1400 rpm. -
Yes , the one with the 9 speed is a former Swift truck . Dealer guy said that it was easily converted over to a 13 but I haven't checked yet but I WILL . I like the 13 speed truck a little bit better and am trying to get an idea of what the rear end conversion would cost . Do any of you have a ballpark figure of what that would cost ? In a previous post , somebody said they would convert it to a 3.55 - I was thinking 2.89. Wouldn't the 2.89 in a 13 speed be better for mileage than a 3.55 in a 13 speed ? Also I guess that I forgot to state , I will be running 22.5 LP tires .
Page 1 of 3
