3 pedal auto shiftshift won't go into gear?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by BAYOU, Oct 9, 2012.
  1. BAYOU
    BAYOU Road Train Member
    2,847
    1,592
    Sep 23, 2010
    Beaumont,Tx
    This is a 02 Freightliner with a 10 speed the light on the dash just keeps flashing and won't go in reverse or foward gear was working fine backed up to a dock now it won't go in gear?
  3. bender
    bender Road Train Member
    2,105
    1,356
    Jul 20, 2010
    Don't Kid Yourself
    Did you shut it off and then restart it and try again?
  4. Frenzy
    Frenzy Medium Load Member
    331
    186
    Mar 24, 2008
    Seattle, WA
    disconnect the battery, wait a min, then reconnect and try again. This kind of fault can happen if the truck is shut down in gear, or was torqued locked. Removing power should cause the transmission to go thru a full cycle and clear itself. It is possible that a sensor has failed.
    good luck
    volvodriver01 Thanks this.
  5. morehp
    morehp Medium Load Member
    699
    206
    Jun 18, 2012
    Is it the service light or the arrows flashing if arrows are flashing you need to adjust the clutch brake
  6. Gear head
    Gear head Medium Load Member
    532
    91
    Apr 1, 2012
    Belair,md
    The arrows also tell which way to move pedal for it to go into gear. The clutch has to be adjust just rightfor this trans to go into gear. There is a way to get codes out of trans. by turning key on and off twice for active faults and four times for inactive I beleave this is right but check its been awhile since ive worked on eaton auto shift.
  7. BAYOU
    2,847
    1,592
    Sep 23, 2010
    Beaumont,Tx
    I called a sevice guy out and soon as he plugged it in he said that's what it is the sencer is not reading the shaft he said he thinks the clutch needs to be changed but it's back going $128.00 call out wasn't that bad!!
  8. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    Go ahead and replace x-Y module doohickey. I read its a common thing that fails at the worse possible time.
  9. Gear head
    532
    91
    Apr 1, 2012
    Belair,md
    These autoshifts are junk
  10. morehp
    699
    206
    Jun 18, 2012
    Iv had a lot to do with the 18 speed ones gen 2 and gen 3 It's usually the truck wiring that gives the trouble.occasional x y controller failure, or they get torque locked. The worst part is they all come with a solo clutch which seize up and don't adjust. The service manual is available online for them and-very handy for a driver with a few clues. Tells you the procedure to check for active, logged , and clear faults with the ignition key.
  11. striker
    striker Road Train Member
    6,023
    6,438
    Aug 8, 2009
    Denver, Co
    if the sensor is not reading, that has nothing to do with the clutch needing replaced, that's the sensor. Mine torque locked one morning last week, Shut the truck off, let it sit two or three minutes, then back on, took about 3 times doing this and it started. Have had it happen in the past, XY failures are common if you abuse the truck or once you get above 300K miles (lifespan varies from 300K to 600K for a set of XY motors), clutch failure is the last thing, typically your clutch brake will fail first, but many times to replace it the whole thing has to come out.
