3 view dash cams?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Sumothertrucker, Dec 25, 2012.
  1. Sumothertrucker
    Sumothertrucker Light Load Member
    88
    16
    Jan 10, 2011
    I c corn
    Sorry, I'm not patient enough to read miles of threads on dash cams. I am looking for a front and side view system that's affordable. Any suggestions?
  3. cuzzin it
    cuzzin it Road Train Member
    3,498
    8,791
    Jan 19, 2008
    Berea, KY
    yes, read the posts, not that many, won't take long :mtongue:
    ralph Thanks this.
  4. Dieselboss
    Dieselboss Technology Contributor
    1,648
    1,365
    Feb 19, 2009
    DieselBoss.com
    So you want to be able to view AND RECORD on three cameras, correct? (front windshield and 2 outside cams pointing back on left and right?)
    A. If so, how many hours or days do you want to be able to record before it loops and begins to record over again?
    and
    B. What is "affordable" in your estimation?
    ralph and Sumothertrucker Thank this.
  5. flood
    flood Road Train Member
    4,161
    4,031
    Dec 25, 2010
    use 1 dash cam (ta has them for 99.98 ) aim it so it can see the nose mirrors...... do a upgrade to a 32 gig card.. that will give you 8 hr's of 720 HD before it loops set it for 1-3min record time
    Sumothertrucker Thanks this.
  6. The Gryphon
    The Gryphon Heavy Load Member
    826
    445
    Nov 3, 2011
  7. Sumothertrucker
    88
    16
    Jan 10, 2011
    I c corn
    Correct. One forward and two rearward. As long as the the quality is there I guess I'd spend a couple k but would like to keep in the $500 or less range. The only one I've seen for this style is from Windshieldcam.com. That looks like what I'm after but awful pricey. Would like to go 4 to 5 days before it loops back.
  8. Sumothertrucker
    88
    16
    Jan 10, 2011
    I c corn
    Thanks. You've been been very helpfull
  9. Sumothertrucker
    88
    16
    Jan 10, 2011
    I c corn
    Thanks. Looks like they have a location in chicago. I'll check it out.
  10. cuzzin it
    3,498
    8,791
    Jan 19, 2008
    Berea, KY
    Aw twas nuthin
  11. Dieselboss
    1,648
    1,365
    Feb 19, 2009
    DieselBoss.com
    • Cam 1: inside windshield or dash pointing forward, 150 degrees wide angle, day/night low lux
    • Cam 2: outside on left mirror pointing backward, 120 degrees, infrared night vision, waterproof
    • Cam 3: outside on right mirror pointing backward, 120 degrees, infrared night vision, waterproof
    • DVR (max of 4 cams) with 250 gb hard drive. This size allows for approx 6 days of continuous recording before over-writing oldest.
    • 7" dash monitor and all wiring
    • GPS enabled for viewing video simultaneously with a Google map overlay when using an internet-enabled computer
    This would run about $1,195. (link)
    There are many variations, like bigger hard drives, heated cameras, dual monitor for the bunk, trailer disconnect, etc.
    I don't know of any that do what you are looking for for $500 though.
    Hope that helps clarify it somewhat.
