Does the FMCSA's COVID-19 Emergency Exemptions & Waivers override the 30-minute break rule?
From the FMCSA Exemption: The latest extension continues to offer relief from the hours-of-service limits in 49 CFR 395.3. This means eligible drivers are not required to have a minimum amount of rest and may drive after the normal 11-hour driving limit, 14-hour duty limit, and/or 60/70-hour weekly limit. They must be in compliance, however, with all other federal safety requirements related to driver qualification, vehicle inspections and maintenance, drug and alcohol testing, licensing, cargo securement, etc. They also must log their time as they normally would, whether using paper logs, electronic logs, or short-haul time records.
The above specifically mentions the 11/14/60 or 70 limits. It's silent on the 30 minute rule. 49 CFR 395.3 is the HOS regulation.The loads are definitely exempt based on freight content and the shipper/receiver.
Unrelated questions: If you are using the Big Day exception, or otherwise driving beyond one of the other limits, stopping to take a 30 minute break can increase the length by which you exceed the normal limits. I assume it's better to take the 30 minute break if it is necessary than not take it and add that violation to whatever length of another violation?
30 minute break & COVID-19 Emergency Exemptions & Waivers
Discussion in 'Trucking Industry Regulations' started by tscottme, Feb 15, 2022.
Does anyone even qualify for the covid exemption anymore?
The 16 hour "big day" exemption only affects the 14 hour clock, no others. If you hit your 8 hour clock it's no different than if you hit your 14. I.e. it's a violation.WildTiger1990, Keepforgettingmypassword, Bean Jr. and 1 other person Thank this. -
ZVar Thanks this.
I found this: Summary of Hours of Service Regulations | FMCSA
Adverse Driving Conditions
Drivers are allowed to extend the 11-hour maximum driving limit and 14-hour driving window by up to 2 hours when adverse driving conditions are encountered. -
"big day" is for local guys. There is a few criteria.
1. Not used in the last 7 days, or last reset.
2. Start and stop in the same location for the last 5 days.
3. Something else minor I can't remember....
It can be used for any reason, or no reason as long as the criteria is met.tscottme Thanks this. -
Not being sarcastic. 14 hours is a long day for me. Staring down the barrel of 16. Omg
I know I'd rather run an hour to get back to the yard, and by extension, my bed than be stuck in a daycab for 10 hours.Keepforgettingmypassword Thanks this. -
ZVar Thanks this.
Just out of curiosity, I’d like to know what the accident stats are compared between standard drivers and guys running longer under state of emergency allowances.
Calling Scalemaster.
