30 minute break?
Discussion in 'Questions From New Drivers' started by Nsuaqcat, Apr 22, 2020.
  1. Nsuaqcat
    Nsuaqcat Light Load Member
    55
    52
    Apr 11, 2020
    Wyoming
    So let's say I start my day and I'm on the clock for 30 minutes, And then I go off duty for 30 minutes and my clock resets back to 8 hours what happens to the other 7 and a 1/2 hours?
  3. Eddiec
    Eddiec Road Train Member
    2,291
    3,514
    Feb 2, 2015
    Nothing. It just means your next 30 minute break is due in 8 hours. You still have a 14 hour clock from the time you originally logged on duty.
  4. Nsuaqcat
    55
    52
    Apr 11, 2020
    Wyoming
    OK now that makes sense
  5. ZVar
    ZVar Road Train Member
    10,911
    23,832
    Sep 10, 2010
    Flint, MI
    The regs state a 30 minute break is required within 8 hours of the last break of 30 or more minutes.
    Means you can start, for example, at 6:00, work until 6:30 and take a 30. Your next 30 minute break would be due at 15:00.
  6. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    The problem is it aint stopping.
    Tick TOCK Tick Tock... sort of like cinderella hoping the pumpking company does not turn with her inside.
    Dave1837 and MTN Boomer Thank this.
  7. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    As said, you now have to take two 30 minute breaks in your 14 hours?
    Roger McG Thanks this.
  8. BackwoodsGA
    BackwoodsGA Road Train Member
    1,949
    10,054
    Mar 18, 2012
    Elgin Nd
    Yup.
    meechyaboy Thanks this.
  9. MACK E-6
    49,714
    234,662
    No, but it’s certainly possible to wind up in the position of that being necessary.
  10. meechyaboy
    meechyaboy Heavy Load Member
    796
    1,227
    Oct 4, 2018
    Detroit, Michigan
    so You have a 14 hour day total
    11 hours of drive time
    You can only work 8 hours consecutively before needing a 30 min break
    You can take A 30 anytime you want but it only resets the 8 hours till you need another 30.
    There are times where you’re just sitting off duty and get a 30 or longer in. But generally if you want to keep moving wait till youre at least 5 and a half in to take your 30 because the most you can get back out of your 14 is 8 at that point and you wouldn’t need another 30.
    Now depending on your truck and how sensitive the elog is you can get away with moving through a parking lot getting unloaded without starting your clock at all. Do a very thorough post trip at night wake up do a pretrip off duty (if you’ve done a thorough post trip a thorough pretrip shouldn’t take long) Go on duty and show a pretrip when your ready to roll if you can instead of starting that clock and letting it tick
