34 hours = The Law or Optional ?
Discussion in 'Questions From New Drivers' started by Jumpman, May 17, 2021.
  1. Jumpman
    Jumpman Light Load Member
    207
    473
    May 13, 2021
    Can someone please explain to me who/how the 34 hour rule is applied.
    You can drive up to 11 hours per day and you are limited to 70 hours of work in a 7 day period?. So the 3 hours of allowed non driving working time per day is included in the 70 hour limit or just actual behind the wheel time applies to the 70 hours?
  3. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    70 hours in EIGHT days, not seven. On duty time, both driving and working. The 34 hour reset is an option, not required. NOTE: If you run into Canada, they require a 36 hour reset, 34 will not help, but you can drive 13 hours in Canada.
  4. Jumpman
    207
    473
    May 13, 2021
    So if the 34 hour reset is optional then you can run up to 70 hours of driving and work time every 8 days non stop.
    Do most OTR companies follow the 34 reset or just the 70 hour 8 day rule ?
  5. Dockbumper
    Dockbumper Road Train Member
    3,778
    9,860
    Apr 29, 2020
    If you spend an average 8.75 hours combined on duty and driving, you will never have to take a 34 hour reset.
    Here is an example of my current clock.
    I have 9 hours and 49 minutes coming back at midnight, plus 1 hour and 3 minutes carried over from today's clock, for a total of 10 hours and 52 minutes. Midnight is based on your Home Terminal time zone, not local time.
  6. Dockbumper
    3,778
    9,860
    Apr 29, 2020
    I manage my own clock. The company does not dictate how I run. All they expect of me is to pick up and deliver on time, safely and legally. There are times when I choose to run out my clock and take a 34 hour reset. There are other times when I choose to run on recaps hours.
  7. Jumpman
    207
    473
    May 13, 2021
    ok, that makes sense. Thanks for taking the time to explain it so well.
  8. Dockbumper
    3,778
    9,860
    Apr 29, 2020
    I might add that I won't go over 9 hours tomorrow. I want to carry a couple of hour over to the next day that only has 6 hours and 47 minutes. It takes a while to learn how to manage your clock. The hours you see in that picture did not happen by accident. I have purposely set them that way. I have been on recaps for almost 3 weeks.
  9. Rideandrepair
    17,336
    56,249
    Aug 8, 2015
    Usually depends on what fits your needs.
    NavigatorWife and tscottme Thank this.
  10. Moose1958
    Moose1958 Road Train Member
    15,167
    33,405
    Dec 17, 2010
    Williesburg, Virignia
    There are some basic misconceptions about the 34-hour restart! First, it's not a legal requirement that a driver stops for 34 hours at any time. I can't find the correct words right now for this part but will just say what I mean. It is ALSO not an option. It simply is! There is no regulatory requirement to take one BUT once you stop for 34 hours your clocks reset AUTOMATICALLY! Most carrier HOS computer systems are set up this way!
  11. Dockbumper
    3,778
    9,860
    Apr 29, 2020
    If you have used up your 70 hour 8 day clock in 5 or 6 days. You can not legally drive again until you have taken 34 consecutive hours off duty.
