3406 b air compressor drive gear torque spec
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Freightshaker3406b, May 31, 2020.
  1. Freightshaker3406b
    Freightshaker3406b Bobtail Member
    I had to pull the from cover an replace that back plate the compressor bolts too wonder on the proper torque spec on all the bolts pertaining to the replacement of the back plate
  3. PE_T
    PE_T Road Train Member
    What’s the engine?
    I’m reading that the air compressor gear for a DD15 engine will need 155 to 185 lb·ft. It also says that the threads are left-handed.
    Sometimes you can find the info you are looking for in installation instructions online (PDF file) by using the manufacturer’s name and model number.
  4. AModelCat
    158,322
    You're just looking for torque specs for normal hex head bolts? If so, CAT generally uses the generic torque spec based on bolt diameter and grade for that kind of stuff.
    Now a nut on a drive gear or something like that, CAT would normally give spec and procedure for that.
    Post your engine serial number prefix and somebody should be able to look up what you're looking for.
    PE_T Thanks this.
