3406b bearing roll
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by tj379, Sep 13, 2022.
  1. tj379
    tj379 Light Load Member
    237
    226
    Nov 10, 2019
    ontario
    hi, i have a 3406b with 200,000 miles on it since its last rod n main , thrust, bearing replacement, was wondering what the recommended service interval is for these or what everyone does them at milage wise, my oil pressure is normal hot n cold , runs fine but just wsnt to do as preventative maintenance,ALSO!, im thinking to do this myself as i learned the old schooler gye who id like to do this job and has done in past is in some serious health conditions he needs to focas on, basically any tips and mains n rod torque specs would be appreciated , its a 7fb engine, should i replace oil pump spring for a new one or stiffer one?whike in there? THANKS!!
    mile marker 27 Thanks this.
  3. AModelCat
    161,476
    I don't even know if bearing rolls are even really needed anymore. The oil technology has advanced threefold since the days of the 3406B's.
    Bean Jr. and tj379 Thank this.
  4. tj379
    237
    226
    Nov 10, 2019
    ontario
    really! iv never bin told that , just bin told mechanicals should be done every so often, i dont run no special oil in it just rotlla t
    Yousername Thanks this.
  5. 062
    062 Road Train Member
    6,283
    33,797
    Oct 20, 2013
  6. Yousername
    Yousername Light Load Member
    80
    243
    Aug 30, 2022
    Bout every 500,000 when I had one. Never really saw much wear till about 750. But they were cheap and easy. And 500 was easy to remember
    blairandgretchen and tj379 Thank this.
  7. wore out
    wore out Numbered Classic
    16,706
    204,318
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    The narrow journal motors were 250k. Reason being they ran more timing and liked to be ran higher in the RPM band. 7FB, 4MG, 5KJ were the narrow rods. I have heard the early 3ZJ were narrow but cannot confirm that as I never seen one. Which means nothing lol. Lots I haven’t seen. With the wider journal and less timing the interval was stepped up to 500k.
    Like @AModelCat said oil is much better I don’t think it’s as critical to do them at 250k like it once was. Sometimes more damage than good is done by contamination. But if I hadn’t ever seen the inside I’d have to have a peek for satisfaction of mind
  8. tj379
    237
    226
    Nov 10, 2019
    ontario
    ok appreciate the information, i think ill a just to do thdm in another 50k that put me at 250k, if they look ok tgen i'll stretch out the interval next time! i think iv found torqueing to 90 and 110 foot lbs plus a flat does this sound correct?
  9. wore out
    16,706
    204,318
    Jun 5, 2013
    Rods are 66 and a quarter turn
    Mains are 190 and 2 flats
    blairandgretchen, LameMule and tj379 Thank this.
  10. tj379
    237
    226
    Nov 10, 2019
    ontario
    thanks alot wore out!!
