3406B Cat Jake Break & Retarder wiring
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by bctrucking2017, Jan 8, 2023.
  1. bctrucking2017
    bctrucking2017 Bobtail Member
    7
    5
    Jan 8, 2023
    I have 3406B model cat engine in a1989 KW, T-800. I have the Jake Break dash switch (ON position) Hotwire going to the clutch switch. Hotwire then goes to the fuel pump switch. From there it goes to Jake head. Jake works great like it's supposed to. How do I wire in a Retarder using the same clutch and fuel pump switches so they work independently of each other? Both have their own switches on the dash. In need of help, please !!!
  3. wore out
    wore out Numbered Classic
    16,037
    194,221
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Power actually comes in from the ign side of key switch through the clutch switch to the fuel pump switch. Leaves pump switch to the switch on dash leaves the switch on on dash to Jake heads
    Last Call and Oxbow Thank this.
  4. Oxbow
    Oxbow Road Train Member
    12,900
    133,736
    Nov 24, 2015
    I'm not sure on the location in a KW, but there is a pressure regulator for the retarder somewhere behind ir under the dash. You should be able to chase the airlines from the retarder handle down to the regulator. Our Pete has a electric over air switch to run the retarder off the switch like a Jake, and it is in conjunction with the regulator. The wiring to the air switch should be the same as the Jake. When using the switch on the dash rather than the lever, you will get full pressure (whatever the regulator is set at, and it is adjustable) all the time. At least that is the way they are on our 89 Pete's.
    Edit to add:
    I didn't answer your question. @wore out described how the wiring to the Jake should be. I believe you should be able to tap into the wire coming into the Jake switch, and power the retarder switch from that.
    wore out and Last Call Thank this.
  5. bctrucking2017
    7
    5
    Jan 8, 2023
  6. bctrucking2017
    7
    5
    Jan 8, 2023
    So your saying if I start out with hot wire from ignition switch to clutch switch then to fuel switch, up to dash switch then to jakes it well isolate jake from retarder if retarder is wired the same?
    wore out Thanks this.
  7. wore out
    16,037
    194,221
    Jun 5, 2013
    That is why it’s wired backwards in some folks eyes so that one circuit could run both brakes on 2 switches. Putting a splitter coming out of the power in to the Jake switch would work but isn’t the right thing to do technically. Also would want to insure that power goes through clutch switch to fuel pump switch first as well. The Jakes should loose all power at the switch by touching accelerator or clutch.
    Oxbow Thanks this.
  8. bctrucking2017
    7
    5
    Jan 8, 2023
  9. bctrucking2017
    7
    5
    Jan 8, 2023
    Yes everything works great the way I have wired in now but both jake & retarder both come on, can’t use just one or the other. Makes sense changing wiring to your way to isolate jake from retarder at the dash switches. I will give it a try in the morning & see if it works!!! Thanks it’s been giving me a major headache !!
  10. wore out
    16,037
    194,221
    Jun 5, 2013
    Yes if you take the positive from that feeds the Jake switch and feed the retarder switch. With retarder off and Jake on the retarder switch should not have power out of both legs. With retarder on is only time the switch should have power on both legs. I have seen the air over electric switch stick in the on position or the wrong type air switch used. Getting it back “right” would be best even if troublesome rather than wiring it up to work
    Oxbow Thanks this.
  11. Oxbow
    12,900
    133,736
    Nov 24, 2015
    I guess I was thi
    I guess you would have to install an old style Cummins push button fuel switch on the throttle linkage to keep them separate as the fuel switch has spade connectors, and the circuit would end up joined there anyway?
    Our blue truck has both jakes and retarder, but no electric operation of the retarder. The white one only has a retarder, and can be operated either with the hand valve or by electric switch, so neither of them have dual electric operation, and I don't have an example of how the factory would do that.
