3406b cat
Discussion in 'Kenworth Forum' started by alabamafiddler, Jun 13, 2014.
  1. alabamafiddler
    alabamafiddler Bobtail Member
    It will not take fuel slowly. It surges and jumps all at once when it takes the fuel. Any idea why?
  3. wore out
    wore out Numbered Classic
    15,845
    191,670
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Several ideas, course we all describe things differently. if it is lacking fuel it will kinda stumble around after you mash it then all at once pick it up and be gone. anything from bad filters to inlet lines hoses sucking air or coming apart causing blockage. Does smoke accompany this problem, have you tested the anaroid. Did it show up after it was worked on for something, or gradually on its own.
    The line cming into the lift pump from the filter base is known for coming loose at the pump side and sucking air. Also could the valves be set wrong, worked on one last week the flywheel wasnt in the right position and the valves were set with it pinned which was bad out and it showed lol. have you checked the timing?
  4. w9l
    w9l Medium Load Member
    316
    513
    Oct 12, 2013
    Everything wore out said first, then possible rack binding? Possible governor wear issues ?
  5. Madnessnnp
    Madnessnnp Bobtail Member
    5
    If no smoke, it's filters. Mine did this too. I'll try to post the pics of my filter guts if I get a chance.
  6. Bryson13
    Bryson13 Bobtail Member
    18
    Oklahoma
    Have you or anyone ever rebuilt the timing advance on that pump?
