I saw an ad for a 1995 W900 with a 3406B. Seems a little new to have been shipped with a B model doesn't it? Should be a sweet truck but if it's not original I'd need to do some checking on the emission test laws.
3406B in a 1995?
Discussion in 'Ask An Owner Operator' started by rank, Nov 15, 2014.
It could be original, most confuse the last mechanical C models with the B models. If the engine serial number is 4MB or 3ZJ it's a C. Easy way to tell is if timing cover is more pointed and has eight bolts it's a mechanical C
rank Thanks this. -
The E and the mechanical C were both used in 94 and 95. If it was a mechanical C from factory that has a B in its place you may have the emissions issues you were concerned about
rank Thanks this. -
you will be able to get the B model into the acceptable emissions range with some tinkering of the IFRC valve on the fuel pump. But if the motor doesn't match the tractor it does raise some flags. Something to look into.
I ordered a new 379 in 1994, technically a 1995 year truck with a b model cat
could have been a 94 left over titled as a 95. dealer could do that back then if the truck was not sold that year. my 71 pete had small windows,some guys claimed 72 was the last year for the small windows,wrong they were 71s titled as 72s. i am not sure what year they stopped doing that. plus you could buy a 1693 ta cat motor,hands down one of the best motors ever made for a truck,but you had to like a noise in you motor,i am sure wore out knows about precup injection. be safe out there
It may also be a case of starting life with an early version of an E--and after it was used up--instead of rebuild--found/had a good B and made the swap---remember in the early days of Electronics--many of us were not nearly as tech/computer savvy--and no matter if the motor was good or bad--we were somewhat uncomfortable with the electronics...and if givin a chance were happy to change---not to mention--at least in my world--a Bmechanical was quite frankly the most reliable--easiest to deal w/motor I ever ran...but thats jus me
I know of a guy who thought he had a B in an older Volvo, and found out it was an electronic and he got talked out of fixing it, it isn't just drivers and owners who are uncomfortable with the electronic engines, especially Cat.
He probably got a good deal on that 95 daycab he bought to run in place of it.
The shop is where I live, and I have heard it said about the shop owner before. He does like the N14s, though.
