If I've got my radiator completely full my truck will push fluid out of the overflow tube until it's dropped down 2 inches or so below the filler neck at which point it pushes no more. Is this something to worry about?
3406b pushing water out overflow.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Wildcat74, Mar 25, 2011.
its probabely just expanding with temp and going out--as long as it is keeping pressure and not heating--wouldnt worry about it
I had a 425 B model did the same thing. Not to worry as long as it don't keep pushing it out.
it is normally, especially when it is cold outdoors.
You fill radiator when it is -5 dgr c and engine normal temperature is 93-97 dgr c... over 100 dgr C difference.
When it is +20 dgr c - difference is about 70 dgr.
When it is really cold, below -15 dgr C, if radiator was filled in summer fluid goes down and engine stalls with engine protection, driver adds 3-5 cm of level and when engine is hot coolant leaks out -
Yes, normal. Fluids will expand when increasing in temperature. I has to go somewhere. 2" below the neck is perfect.
Thought that this was the case but wanted to be sure. Thanks all!
