also a few mm larger injection pumps. had one in a 93 379 pete got 6 to 7 mpg with it 15 spd and 3.70 rears very strong engine to turn up the fuel and torque screws on, non electronic that is.
3406c 3.55 rears 15 speed...mpg?good motor?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by favored, Jun 1, 2011.
Page 4 of 5
The C model uses a heavier rod and wider bearing, the main bearings were not changed, a C crank will fit in a B block.
Also the only major difference in injection pump is the style of barrel and plunger that was used, C models used a dual scroll style that offer 2800psi output versus the single scroll style that only pushed 2200psi, cat never made a larger barrel and plunger, just a different style. -
Again, the style change accounts for all of that, but by cats specs all barrels and plungers for the B/C models are considered to be 11mm.
Some Cs were PEECs and some were not. Seems like when the Es came out the PEECs were history and Cs were purely mechanical again.
My '96 mechanical C 425 hp would whomp the 550hp Es 10 years ago but not today because guys like Kurt are around and also I can't afford to keep the hot nozzles in it. -
I'm looking into getting 359 15 over means you split the top 5 gears keep getting mix answers.
There's no splitting gears on a 15
AModelCat Thanks this. -
Jmlviper213 Thanks this.
Page 4 of 5
