3406c mech black smoke on start up with new injectors
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mr79W900A, Nov 27, 2020.
  1. Mr79W900A
    Mr79W900A Light Load Member
    117
    72
    Mar 4, 2019
    British Columbia
    Hey guys had a number 5 injector go so when I pulled them we didn’t know the history of how long they were in so I replaced them all. Now on start up my truck at idle smokes black a lot more then before. My truck is turned up slightly the write way at about 26 psi. Is this just the new injectors causing this. Or a combo of new injectors and it being turned up a bit.
    6wheeler Thanks this.
  3. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    I'm going to replace mine. I have the 3406e.
    I love hearing how great and wonderful Cat parts are that are brand new. I wish I had a Mack
  4. Roger McG
    Roger McG Light Load Member
    165
    198
    Oct 22, 2016
    western mass
    Injectors meaning plungers and barrels in the injection pump? or injector nozzle in the cylinder head?
    mtoo and jamespmack Thank this.
  5. 062
    062 Road Train Member
    6,233
    33,553
    Oct 20, 2013
  6. AModelCat
    160,613
    Proper injectors?
    pushbroom Thanks this.
  7. bjrc
    bjrc Light Load Member
    81
    97
    Sep 14, 2018
    Fuel nozzles for the mechanical cat need the correct nozzle and the correct spacing to focus the fuel spray. The spacing is set with certain thickness sealing washer for the arrangement number of the engine.
    spsauerland and swaan Thank this.
  8. Roger McG
    165
    198
    Oct 22, 2016
    western mass
    If the rack isnt pinned in the pump on # 1 tdc and you set the plunger in the pump and miss alignment by just one tooth in the rack the engine will run but smoke to no end on an idle and skip terribly about 1200 to 1500 rpm
  9. 6wheeler
    2,696
    4,774
    Aug 30, 2009
  10. Mr79W900A
    117
    72
    Mar 4, 2019
    British Columbia
    There’s no skip. It runs good. Sorry fuel nozzles. Just used to electronic and saying other. I’ll try get a video tomorrow morning. It’s not bellowing black but smoking black on idle a fair bit. Where as before it barley had any smoke on idle.
  11. Mr79W900A
    117
    72
    Mar 4, 2019
    British Columbia
    Nozzle inj #20R5169
