3406e blowing white smoke
Discussion in 'Trucks [ Eighteen Wheelers ]' started by wooly, Feb 4, 2008.
  1. wooly
    wooly Bobtail Member
    belton,ky
    I have a 3406E that blows white smoke and sputters just for a few seconds at startup. I had the injectors checked out, overhead ran, hooked up to computer and everything checked ok. Anyone have any ideas? I know it has to be something simple, any help would be apperciated. Thanks
  3. Working Class Patriot
    Working Class Patriot Road Train Member
    12,683
    23,165
    Jan 17, 2008
    Wherever and Whenever...
    Does the smoke stop when the engine warmed up?
  4. wooly
    belton,ky
    Yep, after it cranks it sputters just for a second blows white smoke, and quits. I just got back today from a garage had the injectors checked and the overhead ran. there was no fault codes?
  5. Flyer
    Flyer Light Load Member
    183
    88
    Jan 20, 2008
    Head gasket or cracked head or both.
  6. 550hpW900L
    550hpW900L Road Train Member
    1,874
    1,090
    Jan 29, 2008
    norcal
    Thats normal its cold out, they all do that, mine smokes white for a good 5 minutes sometimes. Unless your are loosing coolant then dont worry about it and truck!
  7. 550hpW900L
    1,874
    1,090
    Jan 29, 2008
    norcal
    Considering the temperature outside right now i highly doubt it, if it was 80*F outside and he was loosing coolant then yeah....... Ive been down that road before on my dads E model.
  8. Working Class Patriot
    12,683
    23,165
    Jan 17, 2008
    If it it continues after "warm-up" that could be the case.
    Listen to the hot side of the engine for any hissing. Sometimes there might be residue seeping between the block and the head but not always.
  9. wooly
    belton,ky
    Before I had the injectors checked, it would do it untill the it got good and warmed up. Now it sputters and blows white smoke and you can smell the fuel. After about 10-20 seconds it stops, but if I cut it off after its ran and start it back it will do the same thing.
  10. RNGTransport
    RNGTransport Light Load Member
    134
    19
    Jul 13, 2007
    Allendale, MI
    My guess is the cold temps are keeping the fuel from buring up completly inside the motor and some of it is expelled thru the pipes.
  11. Working Class Patriot
    12,683
    23,165
    Jan 17, 2008
    Do you have a winter front or shutters?
