3406e engine fan prolems
Discussion in 'Trucks [ Eighteen Wheelers ]' started by MichaelP, Nov 2, 2011.
  1. MichaelP
    MichaelP Bobtail Member
    34
    Aug 19, 2011
    Mayfield, KY
    The engine fan will come on for no reason it will run for about the same amount of time every time this happens I have put a new high pressure switch on it won't do it every day just every now and then
  3. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    Hi Micheal: Recently went through fan problem with 5EK. Was a simple, stupid problem. When motor rebuilt (3 years ago) wire feeding solenoid was cinched down to tight with a zip tie and broke wire. Would only break curcuit occasionally, causing very erratic operation. Found it after about 1 1/2 of searching.
    Most likely not your problem, but just an idea, if all else fails...:biggrin_25514:
  4. MichaelP
    34
    Aug 19, 2011
    Mayfield, KY
    I am begining to think that it has to be something like that because it wont do it everyday sometimes it wont do it for months but sometimes you can bend the hood over and when you start down with the hood that will make it come on wiring around high pressure switch seems to be good I am lost Ground maybe dont know
  5. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Wires will kill you troubleshooting. Look like he said at pressure points or even at the connectors or connector itself.
    Sometimes a wiggle test will reveal it.
  6. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,733
    Jan 30, 2010
    keep stroking.
    i had that happen once found the wire broke at the high pressure switch in side the plastic lining of the wire took forever to find.:biggrin_2556:
  7. MichaelP
    34
    Aug 19, 2011
    Mayfield, KY
    I cant seem to find any broken wires I have pulled and wiggled wires every time it seems to throw a fit and nothing. We took it to a shop and they said it was a grounding problem so we put a new ground on the engine seem to fix the problem for about a month or two but now its back again it is getting so frustrating because it is such a good running older truck
  8. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,041
    Dec 17, 2008
    When they said it was a grounding problem they ment the wire to send the signal for the fanwas grounding against the truck cab or engine. If you have a manual fan switch in the cab, it could be these wires also
  9. MichaelP
    34
    Aug 19, 2011
    Mayfield, KY
    it does have a manual fan switch in the cab and all were plugged in and seemed to be right there at the switch
  10. brenes-built
    brenes-built Light Load Member
    157
    15
    Apr 14, 2011
    Vancouver, Wa
    I had a problem with my fan on a1Lw but it was more than every so often, I eventually had to replace the wiring harness because it wasn't protecting against heat and the wires were getting hot causing the fan to turn on...the section by the water pump was the worst.. Just a thought..
