3406e Caterpillar engine rear Jake brake does not change when activated manually. Front Jake brake operates normally. middle Jake brake pops/sounds whimpy. Any advice would be welcomed
3406E Jake Brake
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Newguy333, Mar 5, 2018.
Page 1 of 3
Sounds like it's time for a tune-up kit in your engine brakes.
When was the last overhead done?
Probably need to take that back Jake off and apart and see if I missed something...... I did also I notice with the front Jake brake solenoid activated a lot of oil came out where the slave cylinder pushes in at the front one number one cylinder but number two didn't have a lot of oil coming out of it... the back one also did the same thing but to no effect. Jake brake did not come on on the back one.
Which model Jake you have and what is first three of your Serial number. On your hold down bolts, is only one a twelve point?
340c, 2sw,4 12 point bolts, one big nut
Oxbow Thanks this. -
Did you inspect slave valves? Did you let oil purge for at least 30 sec when adjusting Jake lash?
Oxbow Thanks this.
Page 1 of 3
